Anyone know of a fix?
BobCAD says I am out of tech support time, so they won't help. They sent this as what to do, but it didn't work:
If the simulation will not work there a couple of things that may cause this follow the instructions below to trouble shoot the problem.
1. The simulation or project directory is improperly set
To resolve this click on Preferences then Settings Default choose Directories and make sure the path is set to …
C:Program FilesPredator SoftwareCommon FilesJobs
2. The virtual cnc is improperly installed or not installed at all
To resolve this, open windows explorer and navigate to…
C:BobCAD-CAM DataBobCAD-CAM V24System Files
Or
C:Program Files (x86)BobCAD-CAMBobCAD-CAM V23System Files
Run the Predator Virtual CNC 2007 for BobCAD.msi file by double clicking it.
I did all that, no change. Then I uninstalled both Predator and V23, and reinstalled. Still doesn't work, but the symptoms are differernt.
Initially, BobCAD would show a little "busy" icon at the mouse cursor for a fraction of a second, and then would "freeze", and clicking on anything would result in a "ding". I had to kill the process in Task Manager to get it to go away and restart.
After reinstalling, the programs, I get a shorter "busy" icon, but then it goes back in to fully functional BobCAD mode. I never get the verify video on screen.
Predator works fine, but I want to see the material get machined away, which I don't see in Predator. That's why I am trying to Verify within BobCAD. It did used to work...
Any ideas on what I can try next?
LinkBack URL
About LinkBacks
