Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 08-04-2005, 09:34 PM
trevorhinze is on a distinguished road
Question saving code
The other day when I was playing with v20 I could save a nc file as a .tap file which is what mach2 seems to like. Today when I was playing around The only choices I had were to save a file as a .cad, or a .txt What did I do wrong? ( I am using the Fanuc6 post settings) Thanks for your time.
Old 08-05-2005, 08:42 AM
Jennifer's Avatar
Jennifer is on a distinguished road
I'm using Ver.19 so this may not be exactly the same, but if you go under FILE then SETUP you can change the extension to whatever suits your machine.
Hope that helps.
Good luck!
Jen
