Results 1 to 2 of 2
Thread: Is there a way to measure from one arbitrary point to another?
    Mar 2006
    There've been a few times I wanted to get a quick measurement from Point A to Point B on a drawing. Is there a good quick and easy way to do that in V23?
    May 2008
    under dimension other distance
    is one way should give a straight line dim.
    or right click in work space and select measure
    two entities will give distance between 2 points
  1. Need Help!- Use a point for the start point of a profile.
    By dcskid in forum BobCad-Cam
    Last Post: 03-18-2009, 11:31 AM
  2. Need Help!- Bar Face Arbitrary Designs. X, Z, C, I, J
    By sfilippo in forum G-Code Programing
    Last Post: 09-06-2008, 09:42 PM
  3. Newbie- start of cut in arbitrary rough cycle
    By brummie31 in forum Hypermill
    Last Post: 08-19-2008, 08:00 AM
  4. Arbitrary Stock Roughing - parameters?
    By bakh81 in forum Hypermill
    Last Post: 04-24-2008, 03:21 AM
  5. converting point to point programs
    By kevinwd1 in forum General CAM Discussion
    Last Post: 06-11-2007, 12:45 PM
