Here's a snippet from the Bobcad forum posted by Bobcad:
It's your post...
Edit the post in Notepad. Anywhere that you see the variable 'absolute_coord' change it to 'movement_mode'. You can also replace the 'incremental_coord' with the same command.
Also, you can replace things like 'inch_mode' and 'metric_mode' with 'measure_mode'. This will cause the post to pull the unit of measure from the drawing.
The Inch, Metric, Absolute and Incremental variables format the code after they are called. Their counterparts take their value from the drawing or settings in the Current Settings dialog.
Regards
LinkBack URL
About LinkBacks
