Couple ways to do this:
1. Side Allowance value under the Parameter tab.
This can be positive or negative value.
Will make 1 pass with leadin/out.
Must use Offset Rt/Lt (not Comp Rt/Lt)
2. Stock Remaining + # of Side Rough Passes
Example: Enter .1 for stock and 4 passes, it will compute 4 passes of .025 radial DOC.
The pattern will be: Leadin...1 pass...feed in to next pass depth...1 pass....feed in ..etc. ...then leadout.
Again, must use Offset Rt/Lt (not Comp Rt/Lt)
LinkBack URL
About LinkBacks
