Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 28
Thread: Turning just does not add up
  1. #13
    Feb 2009
    yesterday BCC admitted that V23 cannot produce the proper turning code. they said they will try and correct it. i still cannot believe this has not come up sooner. i understand they are far more advanced on the mill side, but lathes are nothing new.
  2. #14
    Registered BurrMan's Avatar
    Dec 2008
    Quote Originally Posted by DIFF OVER View Post
    Can you attach the post processor you are using for this here???
  3. #15
    Dec 2008
    I think it's an issue where the tool theoretical value (auto calculated) is the exact same value as the radius', and the machine file is set to use the theoretical point to run toolpaths...
    There also seems to be something missing, that would be intended to work here.. A selection of "tool type" is not in the dialogue.. So the system acts as if it only has a cutting edge on the "orientation value" of the toolpath... (perhaps you could look at defining your own tool to see if this makes it work??? I dont know how to test that)
    So with these things couple, the toolpath seems to work if you change either the tool radius amount, or the actual geometry radius.. Here is code where I changed the geometry radius to .0049 (just off of the theoretical point number)... It will do the same if I change the tool's radius amount just off of the number also..
    The post is the default fanuc0T.
    O1 ( FILE FACE GROOVE.NC FANUC 0T SUN. 01/23/2011)
    (JOB 1 GROOVE CYCLE )
    (TOOL #9 SPECIAL FACE GROOVE 0.068 WIDE )
    N1 G30 U0 W0
    G0 G54 G97 S8928 T0909 M03
    G50 S3000
    X.2139 Z.1 M08
    G96 S500
    G0 Z0.
    G1 Z-.185 F.005
    G0 Z0.
    X.21
    G1 Z-.185 F.005
    G0 Z0.
    X.1845
    F.005
    G0
    X12. Z6.
    G97
    G30 U0 W0
    M1
    G0 X.1902 Z0.
    G3 X.2 Z-.0047 I-.0001 K-.005
    G1 Z-.185
    X.2038
    G0 Z0.
    X.2337
    G2 X.2239 Z-.0049 I.0001 K-.005
    G1 Z-.185
    X.2038
    G0 Z.01
    G97
    G30 U0 W0
    M1
    M30
    If you present your post processor here i can see if the other values post in the proper place or not.
  4. #16
    Dec 2008
    I think my whole post was wrong.. I think I just had a parameter not filled in right when testing... Like the tool radius on the finish tool being set to zero, and me looking at the toolpath...
  • #17
    Feb 2009
  • #18
    Jun 2004
    Im having the same issue with V23. The simplest most basic tool nose radius comp
    the software cannot get it right. I do a lot of complicated turned aerospace fittings
    I was hoping V23 would help, but im stuck doing things with autoCad and manually inputing code
    CNC Lathe for sale, Look for "Mori Seiki SL-2" on Ebay or PM me
  • #19
    Dec 2008
    Still no post.....Alright then...
  • #20
    Feb 2009
  • #21
    Dec 2008
    lol...
    BCC themselves cannot make their turning software create good code!
    go ahead and stick with that one....
  • #22
    Sep 2010
    Hey there diff over, regarding the "they say they are going to fix it" part. Please post here and let us know what they fixed? If its in the post or the V23 itself. Thanks....
  • #23
    Feb 2009
  • #24
    Jun 2004
    The question begs, If they do figure it out, Will the solution be made available to V23?
    I also believe the problem does not lie in the posting, its in the main body of the software someplace
    I have wasted many hours fiddling with the posts to see if I can get some valid code for
    the Lathe
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Need Help!- Pinch turning or Balanced turning
      By pradeep in forum Mori Seiki lathes
      Last Post: 09-07-2010, 02:55 PM
    2. Problem- TURNING 17-4PH
      By MoSHO93 in forum General Metalwork Discussion
      Last Post: 03-27-2010, 08:13 PM
    3. Need A Quote- 304 SS Turning Job
      By JMFabrications in forum Employment Opportunity
      Last Post: 11-07-2008, 11:01 AM
    4. Turning Cam
      By Regnar in forum General CAM Discussion
      Last Post: 04-29-2008, 05:27 PM
    5. Turning
      By camtd in forum SolidCam
      Last Post: 08-01-2007, 01:40 PM
