Results 1 to 3 of 3
Thread: plunge rough OUTER profile??
    Aug 2010
    canada
    can anyone tell me how to plunge rough the OUTER profile of something?
    i am using 2D milling and i can get the plunge cycle to work but only on the
    inside of the sprocket profile. my goal is to remove the material from
    between the sprocket teeth by plunge roughing and to do a final finishing
    pass with an endmill rather than roughing the entire sprocket with an endmill
    Apr 2008
    What I would do in V21 was offset my profile by the cutter radius (plus a little to leave for cleanup) and break the contour up into even line segments. I would post the toolpath then manually insert a G81 drill cycle. Crude, but works.
    The same might be done in V23, not sure.
    May 2008
    if this is V 23
    then plunge rgh works inside a pocket
    just draw a circle around the outside of sprocket
    increase or decrease size of circle to control how the tool path cuts
    do a outside in under patterns
    this should be done with a endmill
    Attached Thumbnails Attached Thumbnails plunge rough OUTER profile??-plunge_rgh.jpg
  1. took the plunge
    By bilinghm in forum Benchtop Machines
    Last Post: 01-08-2011, 10:22 AM
  2. Need Advice - Sydney / Outer West Area
    By kiwiken in forum Australia, New Zealand Club house
    Last Post: 12-15-2010, 03:50 AM
  3. Z Level rough with multipule rough tools
    By mbi in forum FeatureCAM CAD/CAM
    Last Post: 02-25-2010, 11:45 PM
  4. Newbie- G71 rough boring - remove final profile pass
    By Busted in forum G-Code Programing
    Last Post: 01-19-2009, 01:08 PM
  5. Took the BIG PLUNGE
    By HelicopterJohn in forum Haas Mills
    Last Post: 01-11-2008, 11:39 PM
