i'm having the same problem...... with v23 and with v24 the only difference is that i DO have predator editor and it still doesn't work!
I have the v23 program without the predator editor, but I thought I would still be able to do basic simulation with the software.
When I create a toolpath and try to verify, I get the message in the title. Do I have to have the editor to do the verify? The training Cds say that I can do that without the predator addin.
Did that change with a build?
Hello,
you must check unter "milling Tools" ricght click General Settings.
There check the directorys.
Mine showed a wrong directory, so i couldnīt post and Verify.
Greetings, Tom
Thanks,
I checked the directorys and they show the factory settings for my install. Is there a particular directory that your are pointing too? Mine all go into the Bobcad folder related to the item.. IE, Cutting conditions, Post Processor and then Tool Pattern
I did, and verified that the files existed and were accessible to windows. they are in place and I have even uninstalled and re-installed in order to try it.
I am running 64 Bit windows 7, I hope that isn't an issue.
Here is a short video of my settings and error to compare.
Error
I found out that in order to verify any posts you have to still have the predator installed to use the verify. If I uninstall the Predator, it quits working. Even though I do not have a license for the Predator software.
Ah yes.. The predator software is the built in Verify and gcode editor's.. The extra licensing just unlocks further functionality.. The built in verify is just an active-x control but still part of the predator install..
Glad you got it going!
