Need Help! Super slow toolpath calculation V23
Results 1 to 5 of 5
Thread: Super slow toolpath calculation V23
    Dec 2010
    United States of America
    Default Super slow toolpath calculation V23
    We are having trouble with the extreme amount of time it requires to calculate a simple lathe tool path. Milling is OK. This morning it was taking 5-10 minutes to calculate a simple one poke groove. This all started when I down loaded the last version, which I'm sure is not the current one. We are on V23.01781595. I doesn't appear to be the computer, as the task manager is showing very low CPU usage. Any help would be Greatly appreciated.
    Charlie
    Feb 2009
    Charlie, the latest build is 1812.
    Mar 2006
    What post are you using?
    Vetsen
    Registered Perfect Circle's Avatar
    Jul 2010
    I have this same problem, but mine gets worse.
    If I use a straight line for geo on the ID or OD as toolpath the Great and Almighty BobCad Crashes. So now I click the save button every 5 secs as im work so not to have anything lost. Long story shot I called tech support and they have no idea what the prob is but want $300 to try and figure it out for me...ehhh..well Just try to put a .010 cham. or fillet at the start of a line for toolpath geo and it will work fine...I found that work around myself..
    Thanks BobCad!!
    Good Luck~!
    Dec 2010
    We are using the Haas TL.Lathe.Pst. I think we had modify it a little, but remember exactly what we did to it or why.
    Charlie
