Results 1 to 9 of 9
Thread: BobCad v23
    Nov 2010
    BobCad v23
    Hey guys im pretty new too bobcad just learning atm... What im Trying too figure out is i made a single part. Now what i wanna do is Take that part and Make 20 of them instead of 1 at a time uising a 4feet by 4feet sheet. this is a 2d part what Program do i use too do this? i dont see anything inside bobcad v23 To do this
    Jason
    Feb 2009
    Use Translate in the Utilities Menu. Or if you want them in circle use
    Rotate. they both have a Copy button.
    David L. Aery
    www.hooksolutions.com
    Feb 2009
    You can also do this from within MACH3, but I don't know the details. You would use work offsets, with each of the 20 positions defined, then just run the same single CAM file 20 times - one at each work offset.
    Registered Perfect Circle's Avatar
    Jul 2010
    You can use the nesting feature under the CAM section of the software
    Feb 2009
    Quote Originally Posted by Perfect Circle View Post
    I'll have to check that out, never used it before. I don't make many parts in multiple, but would be nice to have the capability "in my back pocket" should the need arise...
    Registered bill south's Avatar
    Apr 2005
    An easy method is to draw the stock sheet and use translate with the copy function to place each piece (copy) onto the stock sheet in a manner to optimize your use of material. You can drag each copy or just offset it to coordinates. See the translate screen and it should be self explainatory.
    Hope this helps.
    Bill
    billyjack
    Helicopter def. = Bunch of spare parts flying in close formation! USAF 1974 ;>)
    Feb 2007
    Bobcad does sell a nesting program. One thing to remember is that if you translate them over and up you have to program the whole thing has one part the toolpaths do not translate. Or use G54 G55 etc.. I have not used the nesting program but i beleave it translates the toolpaths.
    Mar 2005
    I use bobcad nesting for my cnc plasma as well as my cnc routers. It works great and will allow you to set the stock distance from the edge as well as in between parts. I average approx 86 % utilization from the stock.
    Dennis
    Nov 2010
    that's the thing i know i can use translate.... the thing is it;s really annoying.. you have too space them out your self... i just wanna pick a part, and let a program do the work... instead of me:P not too be lazy just get more work done!!! so is bobcad nesting worth spending the money on>
    Jason
    1. BobCAD to Solidworks (For sale BobCAD)
      By Robert Lewis in forum BobCad-Cam
      Last Post: 05-11-2009, 05:04 AM
    2. BobCad offer to end all Bobcad Offers
      By Syil_Australia in forum Product and Manufacturer Announcements
      Last Post: 02-01-2007, 06:07 PM
    3. BobCad 19
      By bill south in forum Tutorials
      Last Post: 01-15-2007, 01:56 PM
    4. Thanks BobCad Cam
      By roys29 in forum BobCad-Cam
      Last Post: 12-12-2005, 09:06 AM
