Start your ellipses command and enter the numbers, then set the end angle to "180". Join the ends using line-join.
Run the revolve command and select with caps and 180 degrees, z direction.. Put a number 1 in the x dir field.. Shift clcik the entity and hit spacebar.
Now you can extrude surface the bottom of this object .03 and boolean union the pieces together..
LinkBack URL
About LinkBacks
