Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 06-17-2005, 05:23 PM
Pat Pat is offline
Pat is on a distinguished road
Does V20 program tool tip or tool center
Hello V20 Users,
Does V20 program 3D surface toolpaths using the tool tip or the tool center or will it do both? I have V18 and always forget to set my tools to the correct offset using tool center.
Thanks,
Pat
Old 06-17-2005, 05:30 PM
Kookaburra's Avatar
Moderator
Kookaburra is on a distinguished road
Pat,
Version 20 allows you to use either the tool tip, or the tool center. In the tool path parameter page there are two radio buttons "TIP" or "CENTER" for you to select what you want for your offset. If you are using containment bounderies, you can also select if you want the tool contained within the boundry using the tip or the center. Offsetting your surface or tool is no longer necessary.
"A Helicopter Hovers Above The Ground, Kind Of Like A Brick Doesn't"
Greetings From Down Under
Dave Drain
Akela Australia Pty. Ltd.
Old 06-17-2005, 05:35 PM
Pat Pat is offline
Thanks for the reply, that answers my question!
Pat
Old 06-17-2005, 05:46 PM
Kookaburra's Avatar
Moderator
Pat,
I just generated some screen shots in version 20 of the 3-D tool path parameters for you to see.
ID:	8250   Click image for larger version
ID:	8251   Click image for larger version
Dave Drain
Tool length sensing! Swede FlashCut CNC 15 10-12-2005 07:51 PM
Learning to Program CNC Turning Center Farmer G-Code Programing 13 09-12-2005 12:03 AM
Confused about CNC software samualt General CAM Discussion 22 06-30-2005 08:18 PM
Tool Changer Problems Snel Haas Mills 5 08-11-2004 08:56 AM
Mits wire machine center program turkgeltz Machine Problems, Solutions , Wireless DNC, serial port 0 11-21-2003 04:22 PM
