The back-plotter isn't automatically installed, happened to me both at home and work
programfiles/bobcadv32/system is the directory i believe the back-plotter's install file is saved in
-Jacob
Hi, this is my first post here so hello to everybody!
recently I've bought BobCad-Cam v23 with ART and Predator Simulation Level 3.
I learning how to draw, create toolpaths and wanted to simulate the process but the option Virtual CNC Mill is inactive. In Licenses window, from Help menu I can see that there is license for Predator with correct level.
What am I doing wrong?
Cheers,
expart.
- Need Help!- "Virtual" y-axis of Index machine. Should i buy it ?
- Newbie- CNC Lathe with "Virtual" y-axis. Reliable ?
- FastCut 2" end mill. 4 flutes 7-3/4" OAL, 4" cutting length. 1/2" radius, 79504
- Need Help!- Cutting a 7.1" circle from 0.5" thick 6061 alum - End Mill "loading up"
- "NEW" 1/8" 5 FLUTE CARBIDE END MILL "AlTiN"
-Jacob
Thanks, I can see it.. But now I've got another problem - during installation I'm getting the "Error 1904. Module C:\Program Files\Predator Software\Virtual CNC 7.0\PVCNC_Color.ocx failed to register. HRESULT -2147220473. Contact your support personnel."
Then the same only for PVCNC_Light, PVCNC_Material, SlideColor.
I'm working in Windows 7 32bits.. Maybe this is a problem?
Here's a link to the Visual C++ redistributable that is needed here:
http://www.bobcadsupport.com/tech//vcredist_x86.exe
The installer should install all this stuff you have missing from your install session. Maybe with your setup, when you get ready to do an install, right clcik it and choose "run as administrator". This may have it do the proper install with all the requirments.
Uninstall both predators. Install the Visual C++ runtime from the link. Re-install both predators.
Find this file and double clcik it: C:\Program Files\BobCAD-CAM\BobCAD-CAM V23\NC Verify\reg_ocx.bat
Right clcik your BobCad Icon and select properties. On the compatability tab, select "xp", disable desktop composition and visual themes.
Right clcik the BC icon and choose properties. Select "find target" (or got to location). Find the BobCAdV23.exe and right clcik it and select run as administrator.
Done.
"The module "PVCNC_Control70ocx was loaded but the call to DllRegisterServer failed with erorr code 0x80040200.
For more information about this problem, search online using the error code as a search term."
The same PVCNC_Color.ocx, PVCNC_Material.ocx, PVCNC_Light.ocx and SlideColor.ocx
I haven't had problems with BC.. But anyway - I did it.
Thanks anyway BurrMan
