Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > BobCad-Cam
BobCad-Cam Discuss all BobCad software here.
Old 05-31-2005, 03:52 PM
turmite is on a distinguished road
V17 users???
I need ehlp from any and all v17 users. I have over 500 .dgn files from very early Bobcad/Cam software, as in way back before windows, that I need to filter through and transfer from a cd to my v17. I have tried this 3 different times seperated by months at a time and I get the same thing happening. Floating point error, over flow! Is this a bug in 17?
I don't want to have to fix the old pc these drawings are on if I don't have to. It is slow....slooow......slloooooooooooow.
Help?
Mike
No greater love can a man have than this, that he give his life for a friend.
Old 06-03-2005, 03:27 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
Mike,
i'm not familiar with v17. Do you have access to something like SolidWorks. It's very powerfullon importing dgn's....
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 06-03-2005, 04:35 AM
strat's Avatar
strat is on a distinguished road
what op sys are you running ????? is it the same as your old puter????
i have probs with some of the older stuff not running or reading in xp one solution i found was a fix on xp http://support.microsoft.com/default...b;en-us;324767
not sure if this will help but anything poss. i guess hard to think at 2 a.m.
headed out of town for weekend but will see if i can access puter at friends house
Old 06-03-2005, 06:07 PM
Hi Klox.
Nope on the Solidworks. I have Rhino but it does not import .dgn files
Strat you may well have hit on the problem. The old pc uses Bobcad dos version. I did kinda find a work around though. I also had saved all my .tap files so I have backplotted the corresponding tap file saved it as a .cad file and can work on it from there.
Thanks for the help'
Mike
Old 06-04-2005, 02:21 AM
Klox's Avatar
Gold Member
Mike how many files you want to import? Can you zip and post one or two, so that i can try importing them into SW, exporting to BobWIRE/BobCAD, save it as dxf's and cad's and return them to you....
*** KloX ***
Old 06-04-2005, 08:45 AM
Gold Member
imserv is on a distinguished road
Smile
Vector Cad supports the DOS Bobcad 12, both DGN and ASC file formats. You could download the 30 day demo and see if it will convert to something that Bob17 understands.
Fred Smith - IMService
http://www.cadcamcadcam.com/hobby
Old 06-04-2005, 11:48 AM
HuFlungDung's Avatar
Moderator
I think old Bobcad's dgn file type was totally its own. There is no cross compatability with other softwares. Your best bet might be to export from old Bobcad in dxf, into newer Bobcad, then save it.
Old 06-04-2005, 02:12 PM
Gold Member
Try one of these in this zip file. Saved in Vector 10 today. If you have an old version of Auscad, it will also open DOS bobcad .dgn files.
Old 06-04-2005, 10:59 PM
Hey guys thanks for all the help. I actually got my old pc running again and will start making dxf conversions next week. Once those are done I'll start the transfer.
Klox there are something over 600 programs. Needless to say it is not a task I am looking forward to. I will wait to see if this pc works long enough before doing any zipping. I don't mind showing the files or anything it's just the time thing right now.
huflung thanks for the info about the file type. I can't believe that they put the option in 17 to open .dgn files if it won't open them.........well it will open them temporarily. It just shuts down after opening the drawing!
Fred thanks for the offer and would have taken you up on the offer. If this old pc gives it up before I get done I may still take you up!
Mike
Old 06-05-2005, 03:19 PM
Moderator
Version 18 still could import Bobcad dgn files, so I'm guessing that version 17 could have, too.
I think you've got a case of "Bobcobbelitus", which occurs when the program keeps crapping out because of a bad file save in your temp folder. Clean out your temp folder and try it again.
  #11   Ban this user!
Old 06-06-2005, 08:36 AM
Hu are you talking abaout a temp folder in Bobcad? If so I am gonna need some help finding it. I keep my system temp files cleaned on a regular basis.
Mike
  #12   Ban this user!
Old 07-26-2005, 03:05 PM
Acinch is on a distinguished road
Lightbulb Bobcad probs
Hi
With bob-cad v.17 or 18 and if you are using win.98 you will need to download the 98 patch from bobcad website. It is not the temp files you need to cleanup it’s the windows registry file. That is where bobcad stores its default boo boo’s if too many are created it will bomb out frequently. If you are not familiar with editing your registry DON’T. I have a utility program that will clean up V17 & V18 registry, I cannot post it here but email me and I will send it to you. A very important issue that you need to due in order to keep this issue to a minimum is when you want to exit bobcad close the drawing file first before closing the main program, when you shut down bobcad you should see a blank bobcad screen. I also have V#17 and all 4 training CD’s + all training documents for sale…. I am using V18 now…. I hope this helps
Acinch
Another Certified BobCAD Programmer
Looking for Visual Mill users ninewgt Visual Mill 22 02-04-2011 03:29 PM
Looking For Users ninewgt Ability Systems - LPT Indexer and G-Code 5 04-02-2009 02:37 AM
edgecam users timf EdgeCam 38 10-03-2008 01:19 PM
Inventor users? wjbzone Autodesk Software (Autocad, Inventor etc) 43 10-12-2006 01:28 PM
How many users? S4 Monster SprutCAM 9 11-24-2005 07:06 PM
