Results 1 to 2 of 2
Thread: rapid move cutting stock in verify
    Feb 2007
    Red face rapid move cutting stock in verify
    I m trying to reproduce a column look.
    Its my intention to use a .75 in dia. round bit for this. So I ve translate the lines in -Z, so my grooves width match the pink circles on top.
    I was gonna use 3d engrave for this part of the job, and use a .75 in dia. end mill with .375 round end , that should simulate a .75 round end bit.
    Now the gcode seem ok with a rapid at .1 , the only thing when I verify the simulation show the tool cutting the stock on rapid.
    Attached Files Attached Files
    Feb 2009
    You have not defined any stock, so the block of material it is putting there likely does not represent the material you actually intend to use.
    I would use the profile tool rather than engrave. Make a line that is the actual path you want the tool to take, make it a countour, and machine it.
    The tool you are describing is a .75" ball end mill. You appear to have defined the tool in BobCAD correctly.
    To define your stock, either right click on "Milling Stock", click Edit, and enter in the size of the stock.
    OR
    Draw a rectangle that is the size of your stock, and right click "Stock Geometry" and select the rectangle.
    The verify should look better then. The stock material should be displayed in the BBCD screen, so you can verify the Z height is correct for the tooling assumptions you are using.
    Post back with follow up questions if you have them...
  1. stock verify
    By riverracer in forum Mastercam
    Last Post: 05-20-2009, 06:49 AM
  2. Rapid move axis control
    By mattpatt in forum SolidCam
    Last Post: 08-15-2008, 10:51 AM
  3. verify stock setting
    Last Post: 08-10-2008, 06:27 PM
  4. Haas rapid move ?
    By binzer in forum Haas Mills
    Last Post: 06-28-2007, 08:11 PM
  5. Crash during Z rapid move
    By AndyB in forum Fadal
    Last Post: 03-07-2007, 09:48 AM
