If you have HSP it can often be better to use that than a profile cut.
Without seeing a shape difficult to say really.
Regards
Rob
I sometimes cut arcs in hardwood to make cabinets valence, I usually use the profile with multiple passes.
Is there a way to make your tool cut constantly back and forth ,without having to do a rapid back at the start on every pass?
P.S. this is not a close loop, as I receive the board cut to size and just cut the bottom part .
Regards
Rob
can you cut a straight line in multiple pass back and forth without a rapid plane back at the beginning. I dont have HSP.
One technique that I use for cutting off the edge of the board is to draw a closed shape that extends beyond the boundaries of the piece being cut. Then I use a profile cut. It's 6 in one hand, 1/2 dozen in the other because you're essentially doubling the length of the cut as it follows the profile over the area not being cut. My 2 cents.
Hi Claude
You could set the profile with no offset and then set it to do the total depth using multiple steps and then just edit out the rapid returns at each end from the code, the tool would then plunge to the first depth and run to the end of the cut where it would plunge again and return to the beginning again and so on for each depth.
Not ideal but until BobCAD include the option of "bi-direction" cutting then I`m afraid it`s going to be one or other of the "workarounds" already mentioned(Or any new ones that appear !!!)
Regards
Rob
Hi Rob,
This is the best solution yet, thanks , easier that than what I was pondering, to do a parallel line .001 away or the smallest movement allowed by my tolerance, then joining them and using profile as usual on that closed loop. The rotation could be change to make the last cut at the right line...
