I've been using V23 for a little bit now and some reason when i go to do a drilling operation it doesn't spit out the spindle speed command. Has anyone else had this problem. Also the other day i used the grooving command and some reason it posted the radius rather than the diameter dimension that it usually does. I'm just wondering if anyone else has had these problems and if they have what did they do to fix it besides edit it after posting?
