There isn`t such a tool available right now in BobCAD (Hopefully in the next Build), maybe you could try using a "V-Tool", you won`t be able to do the ball end but you should be able to get your angles.
Or a "Chamfer Mill", there you can set a small and large diameter and your angles, won`t look right on the simulation but it should produce the right tool path for you.
Regards
Rob
LinkBack URL
About LinkBacks
