Unless you plan to use a 4th axis indexer to rotate the part, then you'd need two operations so far as your CAM is concerned, because you'd need to rotate the model on screen to the new position for the secondary operation.
Once you have two operations, you can post them as one program (or cut and paste in an editor to make them sequential), provided you put an M0 between the two operations so that the machine will stop and then you can rotate the part in your fixture. I don't know Bobcad, so I don't know the particulars of how you'd do it.
LinkBack URL
About LinkBacks
