Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 02-14-2010, 01:47 PM
RickDLance is on a distinguished road
Pines Tooling
I'm needing some Pines dies and followers. Does anyone here have some or can anyone here make them?
I need 1.625. 2. 3, and 3.5 OD stuff.
Old 04-26-2010, 09:13 PM
tullsa's Avatar
tullsa is on a distinguished road
pines dies are available for a 2 and 4
what size pines are you trying to out fit ? 1,2,4,or 6 ? each utilizes a different collar
Old 04-26-2010, 09:47 PM
It was originally a 1 1/4. We upgraded the cylinder to make it a #2 capacity.
Old 05-28-2010, 10:03 PM
tullsa's Avatar
sorry for the length between my posts
I've been way too busy maybe and this information may be a little out of date , the pines 2 has about a 20 tons of draw force ,I have bent on a pines 2 ,2 "tube. 650 wall on 4.5 in radius with the arm pressures set at max without the machine stalling but it just barely managed so unless the tube is below .150 wall 12 inches radius on the 3.5 in you may lack the balls to do the job ! I have a few dies available with clamps and backslides as sets ,what are your needs ,I also have a lot of mandrels with some single ball combination's what are you building? maybe a gothic backlide is a possibility and yes I have a few mostly larger sizes 1.5 ,1.75 ,1.875 ,2 , 2.25, 2.5, 3 there are only 4 parameters to set on any bender ( three if your not running a booster !) but its the adjustment of those settings that can make or break the job ,my latest challenge is to bend 1.5in schedule 40 pipe on 2.25 in radius, 80 degree bends with 6 % ovality maximum no internal support allowed
Old 05-29-2010, 09:26 AM
Please PM me your contact info.
Pines Numbers 3&4 Benders Frame Thickness and Nose Thickness morribi Bending, Forging,Extrusion... 6 02-03-2010 09:59 PM
PCD & V tooling? bigz1 Wood Working Tooling 2 09-22-2009 08:09 AM
Pines #2 Tooling RickDLance Bending, Forging,Extrusion... 1 09-15-2009 07:44 PM
Does Anyone Have Old Pines #4 Tube Bender For Sale? morribi Bending, Forging,Extrusion... 1 10-02-2008 04:57 PM
What is Live tooling versus "non-live tooling"? squale General Metal Working Machines 8 11-15-2007 02:38 PM
