Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 12-07-2009, 02:15 PM
Vern Smith is on a distinguished road
Recommendations for small shear/brake
I need a small brake/shear that will handle up to .09 hard aluminum (6061 t6). Twenty four inch width is more then enough. The only hard requirement is that it does not warp the metal when shearing it so a set of hold down fingers are essential. Grizzly and others have combinations that look like they will do the job in the $500.00 area. I have no problem with this price point but was hoping there might be a superior machine on the market for a few bucks more. Years ago I had a Pexto that worked just fine but it was quite a bit bigger and heavier.
I would also appreciate recommendations on a good used machine that would fit these specifications. That would give me a reason to familiarize myself with E bay.
Vern
suggest a small brake (benchtop) Sonicmook56 Bending, Forging,Extrusion... 14 08-18-2011 12:59 AM
Building a press shear, punch brake ogesII General Metalwork Discussion 0 11-11-2009 11:52 AM
A Good Small Metal Shear?? Bingster General Metalwork Discussion 1 09-01-2009 12:33 PM
Ever seen shear tooling for a press brake? Can't be too hard douglasco Bending, Forging,Extrusion... 0 07-27-2008 01:56 PM
Need Help!- Recommendations for SMALL CNC lathe and mill IBigBoy Want To Buy...Need help! 4 07-09-2008 01:58 PM
