Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 11-24-2009, 08:52 PM
Bigtoy302 is on a distinguished road
My CNC pressbrake build
I have been planning this for a long time. I just have not had the time or money to start on the project. I have changed my mind on the design many times. I think I finally have it down the way I want. for the most part it is going to look like any other C-frame style brakes with a few improvements.
Specs:
48" wide
58 tons
6" inches of ram travel
2 axis servo backgage
Mach 3 control with a Dynomotion motion controller for the control of the +-10V analog Parker Proportional valve.
5hp, 2.5GPM pump.
I will be building the entire thing including the cylinders. ( That's what I do for a living.)
I am going to start of with building the 2 cylinders first. The cylinder are 5" bore, 3" rod, and 6" stroke.
Pile of Parts
Rough machining of the base heads. I will finish machine them after I weld them to the barrel.
Pistons are next.
Checking the threads with a Go gauge.
Rod heads next.
Piston rods next
Weld prep on the barrel.
Old 11-24-2009, 10:29 PM
ViperTX is on a distinguished road
How about including some guidance on bore versus piston size.....whatever you're using for the ring material, etc. It would help those of us that maybe thing of building our own hydraulic piston assembly.
Thanks,
Paul
Old 11-25-2009, 09:24 AM
Thanks,
Paul
On this design the piston is .018 under bore size because I am using a 1" composite wear band on the piston. The piston never touches the bore so the major is just for clearance. I am using regular lip seals also on the piston, no actual steel rings. The wear band to bore only has about .001-.002 per side clearance For oil.
Old 11-25-2009, 09:57 AM
BobWarfield's Avatar
BobWarfield is on a distinguished road
Very cool!
And the material you're using for each of the components is?
Cheers,
BW
Try G-Wizard Machinist's Calculator for free:
http://www.cnccookbook.com/CCGWizard.html
Old 11-25-2009, 11:09 PM
Originally Posted by BobWarfield View Post
Very cool!
Cheers,
BW
Barrel: ST52.3 DOM
Piston and rod head: Nodular Iron. I will look at the grade monday when I go back to work.
Piston rod: IHCP
Base head: A36
Old 12-11-2009, 08:04 PM
I finally got some time after work tonight to work on the cylinders again. I got the ports welded on and the Id threaded. I also ordered 2650 pounds of steel for the frame. I should have it next week.
Old 12-12-2009, 02:11 PM
Steve_Watkins is on a distinguished road
Very nice turning work I am watching with intrest!
Old 12-18-2009, 09:45 PM
I got the caps welded on the barrels and milled out a slot then drilled a few bolt holes through. I also got the wrench flats milled on the rods.
I then went and picked up the flame cuts. I had a buddy that works at a steel place get and cut me out a bunch of 1.25" HR plate.
Old 12-19-2009, 12:02 AM
WOW, How much did that plate weigh?
Old 12-19-2009, 12:10 AM
DanOSB is on a distinguished road
from looking at that size aprox 3000 pounds
am i correct?
looking really good so far
  #11   Ban this user!
Old 12-19-2009, 01:09 AM
The 4 pieces where about 2600lbs.
  #12   Ban this user!
Old 12-19-2009, 03:12 PM
lowpull is on a distinguished road
How about a quick sketch of what your completed press will look like. This is a very interesting thread. Thanks for sharing.
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
NEW BUILD: PVC as a build material Smiler DIY-CNC Router Table Machines 12 11-13-2009 04:57 PM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 02:45 AM
Need Help!- LVD Pressbrake? rszemeti General Metal Working Machines 7 04-21-2008 07:34 AM
