| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
| mandrel bending Is mandrel bending when you don't collapse the inner part of the metal? Also is a mandrel bend stronger than a conventional style bend? |
| Mandrel bending refers to using dies to help form the bend. They can be either round or square, and help to control the side deformation of tubing bends. |
| thanks a lot I just want to bend some square stock to make a trailer. I am researching if a mandreal bend would be stronger. And also what kind of pipe bender I would need to bend square |
| "Is mandrel bending when you don't collapse the inner part of the metal?" Yes, the end result is as you say and this is achieved with a special type of bender (mandrel bender) that is very expensive. "Also is a mandrel bend stronger than a conventional style bend?" Yes because you don't have the deformation on the inside of the bend. HOWEVER, none of the above is relevant if you're talking about the construction of a trailer in square wall tubing as mandrel bending is normally used in (A) things such as race car/bike exhaust systems or hydraulic systems where an even flow rate is required due to the consistant internal diameter offered by a mandrel bend or (B) things such as tubular chassis' where maximum strength versus minimum weight is required. A trailer can hardly be considered to fit the above criteria and as well as that I'd imagine keeping costs down is also a consideration. Skippy |
| bending cast iron | Goofour | Bending, Forging,Extrusion... | 16 | 10-21-2006 01:38 PM |
| Bending small aluminum rod | Twmaster | Bending, Forging,Extrusion... | 9 | 08-06-2004 08:50 PM |
| Tube and profile bending | motordude | Bending, Forging,Extrusion... | 1 | 03-12-2004 11:01 AM |
| Bending | wakeboard | Bending, Forging,Extrusion... | 7 | 01-18-2004 06:58 PM |
| Bending info | Klox | Bending, Forging,Extrusion... | 5 | 05-13-2003 11:00 AM |
