Results 1 to 3 of 3
Thread: Making my own bend dies.
    Jun 2003
    Minnesota
    I have a Pines mandrel bender. I have bought bend dies,mandrel,wiper dies and pressure dies from a good tooling house. But I want to take a crack at making my our bend die and clamp die. Has anyone tried this. I have a cnc mill and lathe. I would like to know what material I should use for the dies.
    I'll be bending 321 SS tubing. I don't think the dies need to be hardend.
    Any one with experiance that can point me in the right direction whould be great.
    Jul 2005
    I built a mandrel bender for doing 7/8" dia 16gauge 304 and 316 SS tube. The clamps are leaded steel, the wiper die is Delrin in an aluminum backing and the bending die is 6061 aluminum. At a conservative estimate this bender has done around 50,000 bends and still has the original parts.
    May 2009
    i have 3 pines benders.. i make all of my dies and clamp blocks on my cnc.. it is an absolute must because buying tooling can cost over 5 grand!! i just use regular steel for most of the dies.. some i get heat treated.. and on rare i will make one out of 4140 or 4130 and then heat treated...
  1. EZ Trak Dies mid cut
    By jpboyt in forum Bridgeport and Hardinge Mills
    Last Post: 10-05-2012, 04:50 PM
  2. Advice on using CNC Desktop Milling Machines for making punch/dies
    By gpietersma in forum Diemaking and Diecutting
    Last Post: 09-02-2009, 06:11 PM
  3. Tips for making simple steel rule dies
    By leathersmith in forum Diemaking and Diecutting
    Last Post: 09-25-2007, 04:31 PM
  4. SL10 dies again
    By PBMW in forum Haas Mills
    Last Post: 05-15-2007, 04:45 PM
  5. DIY coin dies?
    By Dougotio in forum General Metalwork Discussion
    Last Post: 11-20-2005, 10:07 PM
