| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
| recycling aluminum How do they do it? I was always interested in how they recycle it and get the round stock and blocks like they do? -garrett |
| Melt the scrap down into ingots, and form the same way they form virgin aluminium. |
| how do you melt it down? What do I have to buy? then how do I form it? |
is there any companies that makes these furnaces and not home made? |
| There very well may be, however, it's so easy to get started. example: I welded tohether a cube (just the edges) from angle iron and fitted the floor and walls with fire brick. (available at a masonry supply) and then a matching sized picture frame for a lid also fitting the brick in that. I cut a vent hole in the top and one side with a hole saw. Then used propane weed burner to supply heat. A cast iron "lead pot" made a cruciable. NOW! Go buy the books to get a good grounding in safety proceedures and an understanding of the dangers involved. Molten aluminum os HOT! AND must be handled with caution, to say nothing of the fumes created!! Good luck, have fun....BUT.....BE CAREFULL! |
thanks but I rather just buy an oven |
| The quality of the aluminum when remelted and recast may be a surprise for you, and maybe not a pleasant surprise. Without controlled atmosphere, and so forth, extra alloys are often added to sand castings which help the flux and flow of the metal. The nice stuff we typically use for cnc machining is electrodeposited, I believe, but I could be mistaken. This is why power stations are built for aluminum smelters.
#10
I kinda get what your sayiing. So I would need a controlled atmosphere to melt it down without getting the extra alloys? Also I heard about smelting from alcoa. What exactly is it? -garrett |
#11
Don't let aluminum "stew" in the furnace. Melt, degas, skim and pour as soon as you get up to casting temperature. Old automobile heads and pistons are fine. Try not to mix them, the outcome is unknown if you mix different aluminums. |
#12
| In my furnace there are two holes the same size, about 3" diameter, one at the bottom on one side for the burner and the other in the top a a chiminey. By controling the thru flow you can make sure that all the oxygen is burned by the torch. Very little oxidation of your metal. I use parts from old lawn mower engines and the like so the alloy is tough! There will be some inclusions and bubbles, but if you have ever worked in industry, especially with cast iron castings, you know that this isn't unusual. As a "home brew" casting the quality of appearance won't be "factory" but then neither is the price. I have built working metal lathes (9x24), milling machines and surface grinders. All looked at least as good as some of the home brew machines shown on this site. Check out some of the books on this web page, especially the one on the charcoal foundery. http://www.lindsaybks.com/dgjp/ The gasses produced are deadly so make sure you are outside with good ventilation, Stay up wind as much as you can and remember ................molten metal is HOT!!! |
| How strong? (Linear rails, aluminum structure) | WoodSnarfer | Mechanical Calculations/Engineering Design | 13 | 07-15-2005 12:29 PM |
| CNC Aluminum | studysession | General Metal Working Machines | 6 | 02-12-2005 10:39 AM |
| aluminum extrusion | georgebarr | DIY-CNC Router Table Machines | 19 | 11-04-2004 10:43 AM |
| Can I use Forstner bits on aluminum? | samualt | DIY-CNC Router Table Machines | 14 | 10-24-2004 01:35 PM |
| Can I dry mill Aluminum? | UCFMems | General Metalwork Discussion | 6 | 07-22-2004 06:30 PM |
