Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 12-05-2008, 03:06 PM
owensexport is on a distinguished road
Dynabend 1 Manual needed
Does anyone have a PDF or printed manual for a Dynabend I unit?
Old 12-05-2008, 03:43 PM
Al_The_Man's Avatar
I have the Operators Manual & the Service Manual and Troubleshooting Guide.
Only in H.C. however.
Old 02-09-2012, 03:09 PM
marky1 is on a distinguished road
Question Dynabend 1
Hello everybody:
I have one problem with my Dynabend 1 controller, when you power on, in the control panel it blinks the "CAL" key and all display windows shows just "0", the motor never runs, if I press the "CAL" key it ligths without blinking but nothing happens!, can any body help me???, or does anybody has the user manual?.
Thank you.
Marky.
Old 02-09-2012, 03:19 PM
Al_The_Man's Avatar
I don't know if I still have the manual, I will check, but in the mean time I seem to recall one reason is if the brake UP L.S. is made/not-made (?), it will do the same thing.
Old 02-09-2012, 03:34 PM
Question
The UP posittion Limit Switch is "clossed" when press mechanism is at UP position and "open" when DOWN position.
I have checked the motor and it brake, but there is no any voltage, motor and brake are with no voltage and you can turn the motor shaft by hand. Í would like to know if that controller symptom ("CAL" blinking) is normal and problem is in the "servo amplifier"!!!.
Thanks.
Marky
Old 02-09-2012, 03:47 PM
Al_The_Man's Avatar
Sounds like a servo/power fault.
You should have resistance on the shaft.
I have retrofitted a few of these with Galil card.
ID:	152358   Click image for larger version
Old 02-09-2012, 04:08 PM
Question
It look very nice!, do you make all that design to interface with the servoamplifier?....In my case do you think that CAL blinking and display "000" is OK and problem is in the amplifier (motor has a resistence of 1 Ohm while brake 10 Ohms, so I think they are OK)????
Thanks.
Marky
Old 02-09-2012, 09:09 PM
Al_The_Man's Avatar
I put the whole system together, designed around the Galil and AMC drive.
I will see if I can dig the manual out and get back tomorrow.
Old 02-10-2012, 12:44 PM
Al_The_Man's Avatar
According to the maintenance manual, if continuous flashing of CAL indicates motor drive or drive power supply, make sure O.T. limits and reset switch is not operated, and check all voltages +40vdc, -40vdc, +15vdc, -15vdc, check motor with external dc supply, push reset sw on servo motor enclosure.
EZ TRAK PLUS manual needed grzeniua Bridgeport and Hardinge Mills 5 03-20-2009 11:05 PM
Manual needed Peat Want To Buy...Need help! 8 03-19-2009 03:21 AM
Bridgeport manual needed bherr Bridgeport and Hardinge Mills 3 04-21-2007 06:29 PM
TWS lathe manual needed MHINK General Metalwork Discussion 0 08-02-2005 10:01 PM
Manual Jog needed Stevie General Electronics Discussion 8 02-27-2004 05:16 AM
