Page 1 of 10 1234 ... LastLast
Results 1 to 12 of 116
Thread: My CNC Bender Build
    Jun 2005
    Indianapolis, IN, USA
    My CNC Bender Build
    I started working on a tube bender as my senior project. I am a senior at Indiana University Purdue University – Indianapolis. I am studying MET. My goal was, and still is, to build a tube bender and to make it CNC controlled via a Windows PC. My goal with this post is not to high light the making of the tube bender. It isn’t difficult to buy a JD2 bender and add hydraulic power; we’ve all seen it done hundreds of times. Instead, I will focus on the design and implement of CNC control.
    I know a CNC tube bender isn’t practical for most, hell, it’s not even practical for me. This is more of an exercise to go beyond the norm, exposing myself to areas I normally wouldn’t have ventured.
    I can't figure out why the forum is programmed to not allow the original creator of the post to not edit his post after a certain amount of time.
    Here is how my system works: I have a Grainger pump, relief valve, and Dayton motor. This connects to a Vickers directional control valve. The valve arrangement is a spring center, 3 way tandem form. What this means is when I release the foot pedal, incoming fluid from the pressure line is automatically dumped back to the reservoir. Ports “A” and “B” are locked. The fluid then flows through hydraulic hose into a Parker 2.5”x24” cylinder. I am proud to say that all mechanical components of my bender are made in the USA.
    I am currently in the beginning of the CNC implementation. I purchased a breakout board and a relay board. The breakout board serves two purposes: it allows me to interface the valve and rotary encoder to a parallel port cable. It also serves to optoisolate the I/O devices (valve, limit switches, stepper motors, etc) with the computer. If a surge occurs, $1 chips on the breakout board will get destroyed, not my motherboard.
    I have some pictures to start off. As work progresses, I will post more. The project is due on December 15, leaving little time.
    My bender as it sits now. Finish work is still required. I have to weld in a shelf for the middle. This will store tube templates and dies. I also need to plate with 20 gauge steel. I am going to powder coat the whole thing once it is complete.
    I will have many more pictures to follow in the next few days.
    Jun 2005
    Here is my breakout board:
    Here is the relay board:
    Offsetting the boards from the case with motherboard risers:
    The box with the boards mounted:
    I haven't decided whether I will make a small 5V DC power supply, or if I will just tap off the PC. I like the idea of having a separate power supply for the boards. Both boards require 5VDC to run.
    Sep 2008
    Where did you get that breakout board? I'm going to need one of those for use with my Microkinetics Optistep Plus card and haven't found any decent ones yet. The one you are using looks pretty nice.
    Jul 2004
    It's printed right on the board: http://www.cnc4pc.com
    On all equipment there are 2 levers...
    Lever "A", and Lever F'in "B"
    May 2004
    Now here's a project that got my attention. I'll be watching closely and I wish you all the luck with it.
    Dec 2003
    Do you anticipate getting the positional accuracy with a directional valve rather than a proportional as is traditionally used for this application? how are you going to get the arc position feedback?
    Oct 2006
    great project! I'm very interested in the results and comminicating after you are done.
    I would love to try and implement the same cnc response on my Diacro #3 tubing bender in the future.
    How are you ending the stroke? Is the stroke end time based? Or limit switch based with the limit switch position manually adjusted in a mechanical way? Or are you measuring stroke or on the central bending die as an arc?
    Jun 2005
    Die position will be determined with a rotary encoder. It will attach to the center pin, which rotates about the same axis as the die. End and start stroke will be determined by one of two ways. I am not familiar with Mach3 and its abilities to handle rotary encoders. Method one will either use small normally closed infra-red limit switch at the begininning and end stroke. Method two will use the rotary encoder. Simple if then statements will constantly analyze die position. If it is near the end of the cylinder stroke (100ish degrees) I will have Mach3 turn off one of the relays, closing the valve. If Mach 3 can handle simple scripting then it will be easy.
    Dec 2003
    Mach does not see the encoder, there is no feedback to the control.
    Normally this is the responsibility of the servo drive in this system.
    If it was a proportional valve, a step/dir to analogue amplifier could maybe utilized.
    Jun 2005
    NO!!!
    I don't know much about Mach3, but I did see a selection for the Encoder and a selection for the pins for input. I also saw a pulses per rev option. I can't imagine Mach3 can't receive input from a rotary encoder! Please explain how a proportional valve would work better? Don't they just limit flow? They don't offer feedback do they?
    Dec 2003
    Most commercial benders use a proportional valve, also I used one in a retro-fit conversion of a semi manual machine, it is actually a servo valve, the spool is shifted a proportional distance in either direction in order to control the hydraulic flow to move the cylinder proportionately, rather than just on off.
    The valve itself does not offer feedback, but an encoder or other means is fed back to the control for PID control.
    The control for the valve is usually a servo drive amplifier.
    I made mine from a National Semi LM759, but I was using a Motion Card so I had analogue output to the LM759.
    I have not used Mach either, but the servo encoders are fed back to the drives, The manual Pulse Hand wheel may go back, however.
    But even this may prove a bit difficult to get any kind of precision with on/off control and not servo.
    Apr 2005
    Thumbs up Bender
    Nice project If you have used a JD type bender you must know that a slight amount of over bend is required Ex 93dg to get 90 because the memory of the material I havent looked at the comerical CNC bender's enough to know how they do it but you might be able to treat it like backlash comp on a mill ot lathe A second note to do a large bend you have to move the pin in the die even if you have a long cylinder some of the high end bender's move both halves of the bender somthing to look at . Keep up the great work Kevin
  • Page 1 of 10 1234 ... LastLast
    1. DIY Tube Bender
      By Sperstad in forum Bending, Forging,Extrusion...
      Last Post: 10-11-2007, 09:13 AM
    2. Looking 4 someone that would like to build a mini cnc tube/pipe bender for 3/8
      By dbtoutfit in forum Bending, Forging,Extrusion...
      Last Post: 10-18-2006, 10:45 PM
    3. How would you control a CNC mandrel bender?
      By panozeng in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 07-18-2006, 10:34 PM
    4. Rebuilding a Grizzly Bender...
      By InspirationTool in forum Bending, Forging,Extrusion...
      Last Post: 06-03-2006, 07:09 AM
    5. Building a CNC bender
      By packwalkin in forum Bending, Forging,Extrusion...
      Last Post: 04-18-2006, 02:40 PM
