Results 1 to 2 of 2
Thread: Bending Stainless Steel Bars
    Nov 2008
    Red face Bending Stainless Steel Bars
    Using a manual bending jig, I'd like to put a 90 degree bend in a 1/4" x 1 1/2" #316 stainless steel bar. I understand that stainless steel is difficult to bend. Is the problem the amount of force required to make the bend or is it a case of the metal fracturing?
    Nov 2006
    australia
    Hi mate i know this is a old post but as you have probably already found out stainless bar of that diamention is fairly easy to bend and you shouldn't really have any problems bending it if you use the right equipment,and you should be able to pull a tight bend,sorry for the late reply. regards greg.
  1. Bending stainless steel tube, what tool?
    By Sperstad in forum Bending, Forging,Extrusion...
    Last Post: 12-17-2010, 07:11 AM
  2. Bending 7/8" 316 Stainless Steel
    By grantrobarts in forum Bending, Forging,Extrusion...
    Last Post: 05-03-2010, 05:30 AM
  3. Bending stainless steel tubing
    By eljainc in forum Bending, Forging,Extrusion...
    Last Post: 12-27-2007, 02:08 AM
  4. 1/8" diameter 303 stainless steel rog bending
    By ssbender in forum Bending, Forging,Extrusion...
    Last Post: 11-05-2007, 11:34 PM
  5. bending of steel after milling
    By dhiruj in forum General Metalwork Discussion
    Last Post: 03-23-2007, 03:29 PM
