Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 10-24-2008, 01:18 AM
LaserImage is on a distinguished road
Thin aluminum bending
I have a project that I need to bend thin, 0.025, aluminum. Most pieces will just be a 90 degree bend, no problem there. The question I have is on the pieces that have a 45 degree bend - the 45 degrees is on the outside of the "V" shape - am I describing that right?
The pieces are 1.5" x 3", after the 90 bend they will be 1" x 3" - the one with the 45 is 2" x 3" and will be 1" x 3" after the 45 bend.
I was hoping to get by with an inexpensive brake but I don't know about the 45 degree bend. Is this something a cheap brake can do?
I don't have a way to include pics tonight but can tomorrow, if that would help.
Thanks,
Gary
Old 10-24-2008, 02:40 AM
TOTALLYRC is on a distinguished road
If the brake can do 90 degree bends it can certainly do 45 degree bends. It all depends on how close to 45 degrees you need to be.
The inside and the outside should both be 45 deg after the bend unless I completely don't understand what you are trying to do.
Mike
Old 10-24-2008, 11:22 AM
Mike
Only true because I didn't explain myself very well...
Here is a picture of what I need to end up with.
Old 10-24-2008, 11:39 AM
blackbeard52 is on a distinguished road
A very easy bend on a brake..even a cheap Harbor frieght shown here http://www.harborfreight.com/cpi/cta...266&pricetype=
Old 10-24-2008, 12:09 PM
That brake says it can bend up to 120 degrees - won't that leave me with a 60 degree angle?
Name:	45 and 60.jpg‎
Old 10-24-2008, 12:53 PM
Med-Pac is on a distinguished road
A cheap and dirty way to make that brake work would be to add a shim to the bottom die (the one that swings towards you as you're bending). You could also place the pcs in the brake and squeeze them the last 15 degrees also.
Mike
Old 10-24-2008, 02:32 PM
Oh OK sorry for that brain fart..... here is one that will do the job... a little more but will bend to 135degrees http://www.harborfreight.com/cpi/cta...emnumber=45877
and another that is cheaper but will certainly do 20 ga. and 135 degrees http://www.wttool.com/product-exec/p...ake_WT_Import_
Old 10-24-2008, 08:17 PM
I would call it a 135 degree bend, but I haven't had my coffe yet. It all depends on your point of view. Mine is usually wrong.
Most of the small brakes will bend this, you would have to just make sure because it is near the limit of how far I have seen them bend.
Old 10-27-2008, 11:35 AM
BJ-DEKA's Avatar
BJ-DEKA is on a distinguished road
another way you can do it is to build a die set and use a press, even an arbor press would work with ow thin the material is. we make them out of aluminum all the time
Old 10-27-2008, 06:29 PM
dgapilot is on a distinguished road
Don't forget that depending on the alloy, you have a minimum bend radius (the radius at the apex of the bend). If you try to bend the material with a smaller raduis, it will crack. If you need a larger radius that the nose of the brake, just wrap a piece of amterial around it to give you the radius you want. Also be sure you bend aluminum across the grain if you have a choice. (the grain runs with the mill markings) If you are making 2 bends 90 degrees from each other (i.e. a box), lay out the flat plate on a diagonal.
If you use the proper bend allowance and set back for the radius and thickness, you can make a very accurate flat plate layout. Here is a site with info for calculating bend allowance http://www.engineersedge.com/bend_allow_calc.htm
David
  #11   Ban this user!
Old 10-28-2008, 11:59 AM
Thanks to everyone for the help. I bought the HF brake and made some prototypes - they turned out perfect!
Gary
RFQ Aluminum bending into c channel seansear Employment Opportunity 1 07-28-2008 03:56 PM
Router for thin aluminum Iguanadon DIY-CNC Router Table Machines 4 05-16-2007 09:03 PM
Cutting thin aluminum neonguy CNC Plasma and Waterjet Machines 2 10-13-2006 08:29 AM
Bending Aluminum Bar energyforce Bending, Forging,Extrusion... 1 04-11-2006 11:09 PM
Bending small aluminum rod Twmaster Bending, Forging,Extrusion... 9 08-06-2004 07:50 PM
