Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 10-23-2004, 01:00 AM
Kmed is on a distinguished road
Cold forging aluminum
Hi guys. Well I have a 500 ton Clifton press sitting here and have some time on my hands. I was curious as to how to go about a die design to forged some aluminum parts (1-2 sqin of surface area). Just trying to find a use for it, other wise I am going to sell it. So if you can give me a few pointers It would be appreciated. Tha parts I am thinking of doing are covers for our equipement that are currently being machined out of billet stock.
Here is what I have available for fabrication of the die.
Bostomatic 312 with 5000 rpm main spindle, and 10,000-40,000 rpm finishing spindle. SPC-II control (75 line look ahead in HS mode).
Solidworks, and solidcam for the design , programming.
30 amp ram EDM machine w DRO and fine finish generator.
Harig durface grind w DRO
Ecello vert mill with DRO
Old 05-28-2006, 10:13 AM
ew7437 is on a distinguished road
Where are you located?
Old 05-28-2006, 12:06 PM
Originally Posted by Kmed
.... 500 ton.... aluminum parts (1-2 sqin of surface area)
I don't have any suggestions for dies; it was the numbers that caught my eye.
500 ton = 500 x 2000lbs = 1,000,000lb divided by 2sqin = 500,000/sqin
I think it is safe to conclude you are above the yield strength of aluminum.
Old 05-28-2006, 10:25 PM
EW7437
I am located in Philadelphia,Pa.
Geoff
Well I did some formed sheet metal parts, and it works great. Holding .001 or better tolerances. Looking into doing a few more parts here once I get the shop setup in the new bulding.
Old 01-09-2010, 02:29 PM
mkoelzer is on a distinguished road
delete me please
Aluminum or Magnesium Scrap foamcutter Casting Metals 43 01-16-2007 01:47 AM
How strong? (Linear rails, aluminum structure) WoodSnarfer Mechanical Calculations/Engineering Design 13 07-15-2005 12:29 PM
CNC Aluminum studysession General Metal Working Machines 6 02-12-2005 10:39 AM
aluminum extrusion georgebarr DIY-CNC Router Table Machines 19 11-04-2004 10:43 AM
Can I dry mill Aluminum? UCFMems General Metalwork Discussion 6 07-22-2004 06:30 PM
