| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
Hi All, This is my first post. Thanks in advance for any info. On a manual hydraulic press brake (Jean Perrot model) the pressure is adjustable by means of a potentiometer and there is a pressure gauge which gives a reading in bar. When reading the required force from a bending chart in tonnes per meter, how do you translate this force to hydraulic pressure in order to set the press brake? What is the correct procedure to set the pressure? Thanks, Steven |
| I'd call the OEM for a manual on this. Seems to me there would be a graph or chart on the machine to relate the bar reading to the cylinder bores or effective piston areas to achieve a certain tonnes/m set by a potiometer scale. It may benfit you to add a digital panel meter off a pressure transducer so this reads directly. It won't be exact unless you placed strain gages on the housing and averaged their outputs. A whole lot more calibration there though. No display or tonnage readout on the press? Does it reverse on pressure or ram position? Here in the States it is tons/ft since the dies are rated in tons/ft and the material bend tonnage rated likewise. Regardless, you could start your bend on low pressure and raise it until you can achieve a decent bend. The potentiometer could then be marked with a scale relation to the tonnage close enough. That only applies if you are air bending and using a lower V-die standard of 8 x material thickness. Any deviation to that standard will alter the actual tonnage required according to your bend chart. The tonnage on the pot setting will remain the same, but it will take more pressure for narrow dies and less pressure for wider dies. If your are coining or bottoming the dies, be very careful not to exceed the die load rating. Sneaking up on it is much safer, but knowing their limitations is self preservation. ![]() DC
__________________ Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade. |
| Accurpress has a chart on their website to match the die opening to the tonnage requirements I have never seen a press brake that uses a pressure gauge to set stroke limits? usually there is an adjustable limit switch |
| The Accurpress chart uses 60,000 psi TS for tonnage values. Its an industry standard chart. They list both V=8T and V=10T for 1/2"+. If you plan on bending material based on tonnage alone, your ram needs to be very rigid from left to right. It would also be wise to work in the center of the bed. I would love to see a picture of your brake. |
| NorthStar Press Brake For 20 Ton Shop Press anyone ever use one? | dsmdude | Bending, Forging,Extrusion... | 6 | 04-13-2007 04:01 PM |
| problems setting up LVD MNC800 Brake press | Xerophobic | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 05-12-2006 08:42 AM |
| I need someone with a Press Brake | murphy625 | Employment Opportunity | 0 | 01-25-2006 04:11 PM |
| arbor press pressure | MBG | General Metalwork Discussion | 2 | 04-01-2005 06:26 AM |
