Results 1 to 2 of 2
Thread: Making brackets; bending 1/4" x 3" aluminum flat stock
    Registered guru_florida's Avatar
    Nov 2007
    I am trying to make brackets for the Z-axis tower of my cnc machine. I wondered if this bracket might be tough to make via a bend, but thought I would attempt it.
    I have included the picture. THe bent piece turned out 90 degrees alright, but not at the right perpindicular angle which I think is evident in the pic. During the banging, the left end of the vice the material was flast to the vice, the right side was not. Maybe I could bang it some more into shape, it's not easy banging 1/4" into shape.
    I used a butane torch to heat the metal at the bend. I know, aluminum is such a good heat conductor the heat becomes uniform very quickly. I may not have heated the metal enough,
    ...I am such a rookie bender!!!
    Any suggestions? I dont have access to a metal brake.
    Attached Thumbnails Attached Thumbnails Making brackets; bending 1/4" x 3" aluminum flat stock-dsc00019.jpg
    Dec 2005
    UK
    Dear guru florida,
    Sorry, I know next to nothing about metal bending, ....but I do know that some Aluminium alloys are way better suited to cold forming than others.
    I hope the alloy experts come to your aid.
    Best wishes,
    Martin
  1. Cutting 1/2 x 4" aluminum bar stock
    By KSky in forum General Metalwork Discussion
    Last Post: 07-14-2011, 03:54 AM
  2. Tube Bending Machine Capable of 2"x4" Rectangular Tubing
    By morribi in forum Bending, Forging,Extrusion...
    Last Post: 06-27-2010, 11:47 AM
  3. Need Help!- Bending 1/4" X 1" aluminum bar
    By jeffmorris in forum Bending, Forging,Extrusion...
    Last Post: 07-25-2009, 12:15 AM
  4. Bending a closed box tube from flat stock
    By z28tt in forum Bending, Forging,Extrusion...
    Last Post: 12-07-2006, 02:05 PM
  5. Bending 1/4" aluminum plate
    By SRT Mike in forum Bending, Forging,Extrusion...
    Last Post: 12-04-2006, 09:21 AM
