Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 09-07-2004, 12:20 PM
ToMMY2ooo is on a distinguished road
Cook your chips to make more chips :)
Would it be worthwhile to save all the chips,swarf from a project using the same type of aluminimum to smelt it and re-cast other parts? Obviously coolant would have to be washed away but milling all that metal away seems to me to be a big waste unless you could reuse it for other projects, test pieces etc.
Cheers,
Tom
Old 09-07-2004, 12:59 PM
DSL PWR is on a distinguished road
Yes you can. In highschool we did some aluminum casting, and used everything from swarf to pop cans to old pistons. When you melt everything most of the crap comes to the top (no big worry about oil or coolant) and you skim it off.
Old 09-07-2004, 01:51 PM
InventIt is on a distinguished road
Just out of curiosity, would a casting from swarf have the same machining properties as the original piece? Just wondering if the melting/casting process would change the metals characteristics.
Old 09-07-2004, 02:38 PM
*Registered*
ESjaavik is on a distinguished road
Throw away the swarf.
It will only create lots of slag in melting. That's a waste of expensive heat and volume in your crucible. Also throw the poop cans where they belong, that's not good aluminum for casting. Pistons on the other hand is good if you can get them cleaned first. Heat throroughly before putting it in the melt though. There are lots of crevices that can hold oil or moisture and create an explosion.
If the material is clean and in reaonably large chunks, you will get a casting with close to the original characteristics. You *must* degas, or it will be brittle and with tiny gas pores in it. (There are now less harmful degassers than Hexachlorothane.)
Do not let the melt come in contact with iron, then it will generally not be useable for anything but plaques and figures that will not be machined.
My First CNC Machine, Mr. Chips Mr.Chips DIY-CNC Router Table Machines 81 02-10-2007 10:04 AM
How do you make Bridgeport execute program? Bill Gillen Bridgeport and Hardinge Mills 10 06-14-2005 09:26 AM
Time to make it work DESERT RAT DIY-CNC Router Table Machines 8 02-22-2005 08:30 AM
mounting mill sideways for cleaner screws and chips lesd General Metal Working Machines 1 11-15-2004 09:07 AM
How to make the frame exact signIT DIY-CNC Router Table Machines 5 05-28-2004 03:04 PM
