Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 05-09-2003, 11:25 AM
Klox's Avatar
Gold Member
Klox is on a distinguished road
Bending info
How do you compensate for bends in sheet metal? I ask this specifically as i do not carry my PC with cad software round.
Neo do you perhaps now of formulas to calculate bends and other sheet metal stuff?
While i'm at it what about pipe bending?
Klox
*** KloX ***
I'm lazy, I'm only "sparking" when the EDM is running....
Old 05-10-2003, 11:21 PM
HuFlungDung's Avatar
Moderator
Klox, I am not sure if this would be helpful, but I understand that if you bend a square bar of steel, that the bottom 1/3 of the bar is in compression (shorter) , and the top 2/3 is in tension (longer). This would give you an idea of where the neutral zone lies, which is still the original length of the bar.
Old 05-11-2003, 12:32 AM
HomeCNC's Avatar
HomeCNC is on a distinguished road
Look at:
http://www.massey.ac.nz/~odiegel/bendworks/bending.pdf
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 05-11-2003, 01:23 AM
hardmill's Avatar
hardmill is on a distinguished road
Not sure how to manually. But i believe solidworks takes
care of this for you.
Old 05-11-2003, 12:52 PM
rcrabb's Avatar
rcrabb is on a distinguished road
Are you trying to figure out a cut lenght for piece you want to bend?
Old 05-13-2003, 11:00 AM
Klox's Avatar
Gold Member
bending info
HomeCNC, Hardmill, Hu and Rcrabb thanx for your replies. HomeCNC thanx for the link, i'll go check it out.
When i was still an appy we did a course on the bending of tubing & sheetmetal. At that stage life was a joke so i never took any notes....
Well today i would like to refresh my memory on the bending of different materials as it comes in handy when doing press tools.
Thanx again!
Klox
*** KloX ***
Info on Taig Mill Vs others. Deviant Taig Mills & Lathes 4 11-27-2004 05:17 PM
Bending small aluminum rod Twmaster Bending, Forging,Extrusion... 9 08-06-2004 08:50 PM
Buffers for PPort! Info! vacpress General Electronics Discussion 1 03-16-2004 07:40 PM
Scanner board info Jan General Electronics Discussion 0 12-08-2003 03:26 PM
help with info on steppers jleiwig DIY-CNC Router Table Machines 8 11-22-2003 09:03 PM
