Page 1 of 2 12 LastLast
Results 1 to 12 of 13
Thread: Desktop press & die for aluminum box
    Jan 2007
    I'm looking to replicate an aluminum box similar to the attached photo. I'll use 6061 aluminum somewhere between 1/16" & 1/8" thick (depending on press capacity) which will be milled to the flat-open-cube shape on my CNC Mill and then pressed into form. The final box will be 1" wide, 0.5" tall and 0.5" deep (so quite small...)
    I don't have any experience with the next steps, but would appreciate any comments on the following "next steps":
    1) Mill a cavity form that I will lay my aluminum-box work-piece (which is still in a flat cut-out shape)
    2) Lay the interior-cavity shape on top of the work-piece
    3) Use a desktop press to form the aluminum piece into my mold
    4) I don't yet own a press. Any recommendations on a small (desktop) sized, quality press? Grizzly has one, but I don't like their low-quality I've seen in their other products. I have a decent budget and would prefer to buy something quality - but it needs to be small. (http://www.grizzly.com/products/2-Ton-Arbor-Press/H7830)
    FYI: For steps 1 - 3 above, in case my explanation isn't clear, an analogy would be making a cupcake, where I mill the cupcake-tray for the form/shape, use the actual cupcake as the opposite-piece (which I've also milled) for the inside form/shape, and the wrapper is my work-piece that I am trying to press-into-shape.
    Thanks!
    John
    Attached Thumbnails Attached Thumbnails Desktop press & die for aluminum box-aluminum_box.jpg
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Dec 2007
    Depending on how generous a bend radius you have selected, I'd recommend going with AL5052 H32 or H34. These alloys are way better for brake and press forming. The 6061 T6 has a tendency to crack at the bends, unless you preheat, thus creating 6061 T0, which negates the purpose of having selected that temper.
    regards
    Jan 2007
    Cam1 - Thanks, that's great to know. I'm definitely looking for a tight bend radius, so I'll look for AL5051 H32 or H34. I'm not concerned about the temper / strengeth / etc; this part will not be strssed in any way.
    Any rec's on my process or a viable benchtop press?
    Dec 2007
    Hmmm, I'd probably go the route of Box & Pan brake, and treat the boxes like a sheetmetal box, as opposed to the mold & die method. This method would work fine, provided you didn't want to store liquids. The corners could be designed to be locked, using various sheet metal techniques. I'm not aginst the deep drawing method you proposed, but most of the stuff I've seen that was formed that way was round. I think you would have a %^!! of a time dealing with the material "flow" at the corners.
    regards
    Jan 2007
    Gotcha. I'm happy to experiment and definitely don't need to store liquids - so I'll find/buy a small box & pan brake and see how that goes. Thanks!
    Dec 2007
    cheers
    Aug 2004
    tikka308....if your dimensions are accurate....I don't believe any of the box/pan brakes in the inexpensive category will work.
    I would definitely look at using an 20 ton bearing press....check out bonneydoon engineering.
    If you're making a bunch....well, I would get someone with the equipment to build them.
    Jan 2007
    By dimensions I assume you mean the thickness? I realize 1/8" is pretty thick to bend... but shouldn't I be able to bend a 1/16" thick piece of aluminum that is less than ~1" wide?
    Aug 2004
    Tikka308...the problem with the small brakes is that the clamp pressure is not enough to keep the 1/8 inch material from slipping and you end up with a bend radius that is quite large.
    Best thing to do is take a piece of your stock that has the 4 corners notched or milled...go to Harbor Freight and use their finger pan/box brake to bend your box and you'll see the problems. Also the fingers are usually in 1, 2 and 4 inch width increments.
    Jan 2007
    Just wanted to let ya'll know that I've successfully made my first box! It worked perfect; I used the Grizzly 24" box & pan brake. Details, pictures & video are all on my blog - http://www.nyccnc.com/Herbie/HERBIES..._Tutorial.html or http://tinyurl.com/5zsfhb
    Thanks for the help!
    Feb 2006
    us
    Good video Tikka, I like the way you found the limitation of the brake and then figured out a solution. I also like the barefoot work ethic :-)
    Jan 2007
    Zip - I was hoping no one would notice the barefeet! I saw that when I posted the video and almost re-shot the clip, but figured it wasn't that big of a deal. But to all you youngsters out there: stay safe! proper safety equipment (including shoes!) are important.
  • Page 1 of 2 12 LastLast
    1. Need suggestions for desktop drill Press
      By rkremser in forum General Metal Working Machines
      Last Post: 02-23-2008, 11:56 AM
    2. Newbie- Desktop pc instead of plc
      By axis_control in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 02-06-2008, 08:49 AM
    3. Spade Drill Does Work in Aluminum; Big Hole Boring on Drill Press.
      By Geof in forum General Metalwork Discussion
      Last Post: 02-01-2008, 02:32 PM
    4. NorthStar Press Brake For 20 Ton Shop Press anyone ever use one?
      By dsmdude in forum Bending, Forging,Extrusion...
      Last Post: 04-13-2007, 05:01 PM
    5. Press Break Capacity Aluminum vs Steel
      By voxelman in forum Bending, Forging,Extrusion...
      Last Post: 05-14-2006, 10:58 PM
