Hey guys.
I need to make a 300-400 of these but have never done this type off stuff. Can anyone point in in the right direction on where I can start.
Hey guys.
I have a full shop to make jigs and such, I'm just not sure where to start or what options I have. Any input would be great.
I think I would farm it out to a wire forming company.
The subtle little jog seems like it would be a pain to get right.
Scott
Consistency is a good thing....unless you're consistently an idiot.
I would rather make them myself...
If the OEM has no tooling to offer, I too would get a bid from a wire forming house that might have equipment that would run these for a few cents each. For you to do a run of 300-400, if there is much custom tooling cost, that alone will add in $3-5 range each in tooling costs for such small run batches. Decent tooling to run them on a press or a brake could run 10,000+pcs to absorb that cost. If this is an on-going contract, then it is your call, but don't expect to break even until about the third run.
I think I would look for pre-heat treated material. See if you could request a variance to use 4130HT, presuming you could find 12ga that fit the tolerance. Heat treating after bending would take a special fixture to hold them in shape.
If I had to make them. I think I would make 2 at a time, mirrored at the joggle with a sheared knockout between. Wherein the progression cuts the proper length of material, drops in position, bending the ends, joggle and shearing them apart all in one stroke.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
