Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 07-05-2007, 06:10 AM
bluecolour is on a distinguished road
CNC Bender Clamp Die problem
I encounter some problem from my CNC bender machine, the clamp die and the pressure die has abnormal pressure during this step, and thus the loose grip and scratches. Bending of others parts or other pipe was no problem except for this particular one. Anybody got any answer?
Old 07-06-2007, 03:55 AM
mikek10 is on a distinguished road
What type of machine is it?
All-electric benders offer much finer control of clamp / pdie torques and also allow different settings for different bends.
Old 07-13-2007, 01:52 AM
Hi mike, thanks for helping... I am using a CNC32MRBE machine from Taiwan Chiao Sheng. I think i know what you mean, but the whole process has 8 steps, all the other steps (or bending) is ok except for this one...
Old 08-01-2007, 01:55 AM
tullsa's Avatar
tullsa is on a distinguished road
the marking seems to be a pich mark from the clamp and pickup along the die ,not slipping ,scratches would be 90 degrees to what you have looks like the tube is resting with some wieght on the die master bar and clamp prior to clamping ,I'm assuming thats the bottom in the diagram iether set the distance the clamp opens to the minimum or hold the tube up
Old 11-20-2007, 05:11 PM
altered is on a distinguished road
maybe add grease in the die.
Problem on PUMA8 of spindle speed clamp G92 Ashu Daewoo/Doosan 2 11-04-2007 03:17 PM
CNC Bender Mathematics Questions FishGuy876 Bending, Forging,Extrusion... 4 06-06-2007 11:24 AM
Programming / Setup help for bender. doanwannapickle Mach Software (ArtSoft software) 3 11-17-2006 03:48 PM
How would you use Mach to control a bender? panozeng Mach Software (ArtSoft software) 23 10-18-2006 01:40 AM
Building a CNC bender packwalkin Bending, Forging,Extrusion... 5 04-18-2006 02:40 PM
