Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 04-22-2007, 07:51 PM
synd00d is on a distinguished road
Question Building your own Power hammer vs Factory Hammers
Does anyone have any homemade power hammer plans or pictures. Would it be more practical to buy a factory hammer? If so what brand and or model (50-100#). Are there any power hammers using single phase?
Old 04-22-2007, 07:59 PM
paulC is on a distinguished road
Should be fairly easy to raise a hammer using a cam and drop it when it reaches the top. You could gear it to match any sized hammer with almost any size motor, It would just change the time between strikes.
Paul
Old 05-03-2007, 10:56 AM
ras0112 is on a distinguished road
by simply entering power hammer in your search engine you should get a good bit of info. Two sites that I found most helpful are; angelfire.com and ABA ( appalachian blacksmiths association). You will see many homebuilt machines generally called JYHs (junk yard hammers) built from whatevers handy. Hope this helps.
Old 05-03-2007, 11:05 AM
paulC, I believe what you are referring to is a "helve-hammer". Not really powered by anything but gravity on the downstroke.
Old 05-03-2007, 02:41 PM
Bryne is on a distinguished road
www.bryneselosmide.se
Old 05-03-2007, 03:31 PM
True enough, but if the hammer is heavy enough does that matter. e=mc2 raise the speed or the mass, same result, and it is proberbly much easier to increase the mass. Or is this for sheetmetal work where speed is importent.
Paul
Old 05-12-2007, 09:25 AM
davo727 is on a distinguished road
You could use springs pulling down to accelerate the hammer or a pneumatic cylinder connected to a air tank reservoir. The piston end could be connected to the hammer. Dave
Old 05-12-2007, 03:59 PM
Pook is on a distinguished road
What kind of work are you trying to do?
Forging or sheetmetal shaping?
I have a couple of forging hammers (a 100lb littlegiant and 300lb Nazel self contianed airhammer), and have read and looked up on alot of the homebuilt ones and know people with some.
So depending on what you want to do I can help push in the right directions.
Old 05-17-2007, 03:51 AM
massajamesb's Avatar
massajamesb is on a distinguished road
How about a good source of hammer dies, both for planishing hammers and for a helve?
I have seen the pneumatic hammers that employ a air cylinder, how are you able to switch the air from one side of the cylinder to the other, back and forth, quickly enough to be of any use? I have a plethora of cylinders and spool valves, the idea of using some of this surplus I have gathered is appealing.
EDIT: this is for sheetmetal only, no forging work.
"If the women don't find you handsome, they should at least find you handy"
-RedGreen show.
Old 05-27-2007, 02:11 PM
Knut is on a distinguished road
Hi synd00d,
You need to go to Daniel Gentiles home page and down load the 18 page Krusty spring helve hammer plans for free!
http://www.ferrum.cc/en/plans-drawin...-plans-17.html
It looks pretty good, and is a complete plan by the way.
iforgeiron.com has a two page hand draw design also, lillhmrplan
There are several websites with gobs of different designs. The most interesting design I've seen of late is a fellow from Pennsylvania that has made a spring helve guilded way hammer that is actuated with a squat under slung air cylinder. Great idea for those of us with low ceilings.
Most of these are considered 'forging' hammers. metalmeet and allshops have the rapper type helve hammer forums used for body shaping.
Spent to much time looking for a means to get around purchasing a new compressor to get good hammer control for sheetmetal forming. Best to use air if you want control, plus the mechanical components add up to bucks too.
Alan
  #11   Ban this user!
Old 07-05-2007, 08:34 AM
40fordcoupe is on a distinguished road
I recently attended a workshop to construct a power hammer held by the blacksmith association of which I am a member. The group constructed 19 hammers basically in three weekends. Each attendee got a hammer for the cost of materials. A Mr. Clay Spencer sells the plans and also gives workshops.
The last I heard he was relocating to Alabama so I don't have his address.
Google Clay Spencer Power Hammer and you may find him.
The unit weighs about 700 pounds, is driven by a 1 HP motor through a friction drive. It can deliver from up to almost 300 strokes a minute depending upon how far the foot control pedel is depressed.
I hope this helps you find something.
  #12   Ban this user!
Old 08-08-2007, 03:21 PM
JohnKrumpotick is on a distinguished road
Metal Shapers has information on building a light Helve hammer for sheet metal work.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
building power supply heilcnc General Electronics Discussion 7 04-14-2006 01:29 AM
Building a power supply with decent volt/amperage phantomcow2 General Electronics Discussion 4 03-14-2006 05:33 PM
Building a power supply WilliamD General Electronics Discussion 5 10-20-2005 11:08 AM
Keychain Brass Hammer gdl357 Hobby Discussion 5 02-23-2005 05:28 PM
Building a Power Supply xairflyer Hobbycnc (Products) 9 02-07-2005 05:04 PM
