| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
#13
| Hi I work at a BMW wrecker all we do is take apart old BMWs My advice is to go to the nearest Euro car wrecker and wait for them to toss a cracked M20 head usually they toss the valves with it. Now you have unbent valves. Simple and cheap. |
#14
That's not a bad idea, but specialty auto recylcers in my area are a little scarce. I know of a couple euro shops that might be able to help, though. Thanks! |
#15
| Here's the way I see it. Is the engine block worth less that $15.00 X 7 valves = $105.00. Then there is the gaskets/seals to have to purchase again if the straightened valves don't entirely destroy the remainder of the engine. I wouldn't do it on a bet. Just my 2 cents.
__________________ If it works.....Don't fix it! |
#16
#19
I did'nt have a lathe, I just used a piece of hardwood with a hole drilled down it. I then placed the valve in the hole right upto the head. I could then rotate the valve to see the runout. Small taps with a block of wood on the head and I had them running straight as a die ![]() Lapped them in and the engine fired up and ran like clockwork ![]() All for the cost of a few hours, and a bit of head scratching! Andy |
| "low end" HF Spindle or "high end" router for about $1000? | biomed_eng | DIY-CNC Router Table Machines | 14 | 01-06-2012 12:15 AM |
| Has anyone looked at the "JET" or "Shop Fox" manual machines? | boosted | General Metal Working Machines | 12 | 03-04-2007 09:33 PM |
| Book "Elmer's engine" | Hans-Jürgen | Steam Engines | 3 | 07-23-2006 01:33 AM |
| RFQ- Need 3/32" wire bent | CNCadmin | Employment Opportunity | 5 | 12-18-2005 08:32 PM |
| Add "View New Posts" to "Main Menu" | Mr.Chips | Forum Questions or Problems | 4 | 04-21-2004 10:54 PM |
