Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 03-17-2007, 06:22 AM
*Registered*
davef is on a distinguished road
Can I bend cast iron stove grates?
I'm restoring an antique cast iron stove that was apparently overheated at one time as one of four cast iron grates are bent. I'm wondering if I can place this bent grate into a charcoal fire till it's red hot, bend it straight, then return it to the fire and let it cool slowly as the fire cools over many hours? If not advisable is there an established proceedure for straighten deformed cast parts like that described above?
Old 03-17-2007, 11:05 AM
If it is a true antique, correct age and all that, don't try to straighten the grate it will almost certainly break and then you have devalued the antique.
I have worked with cast iron and have never successfully bent it. I think the reason these grates bend is because it happens very slowly at a high temperature; over weeks or even years. You idea might work but I would support the grate with fire bricks below with a heavy block of steel on top. The weight on top would do the straightening and the bricks underneath would stop it going too far. In theory anyway, I think I would live with the bends.
Old 04-03-2007, 09:47 AM
ADucci is on a distinguished road
mmm this is interesting....
i like Geof's idea... using constant weight to "relax" the bars... i wonder if you could heat it with some oxy acet... (very slowly)
maybe the best thing would be to get a small sample of cast iron and heat try to bend that one...
Old 04-10-2007, 06:44 AM
mattinker is on a distinguished road
Flattening cast grate
davef,
although I havent tried it, I would be inclined to heat it cherry red in your charcoal fire/forge and the press it flat very slowly, reheating frequently. I have built presses using hydraulic bottle jacks in a welded rectangle of small "I" beam or channel. I suspect that a scissor type car jack would be sufficient, the idea being not to put too much pressure on it, bit at a time, re-heat cycles and let it cool with the fire. You will have to have a fire big enough to heat the whole grate evenly.
Matthew
welding cast iron jimco Welding, Brazing, Soldering, Sealing 12 05-11-2007 03:35 PM
Where to buy cast iron plates? Zumba General Metalwork Discussion 2 04-13-2006 09:04 AM
Cast Iron and Grinding Zumba General Metalwork Discussion 2 03-02-2006 01:53 PM
Sources for raw Cast Iron. DieGuy General Material Machining Solutions 4 12-26-2005 09:27 PM
Rust on Cast Iron ChrisJ General Metalwork Discussion 10 05-18-2005 02:06 AM
