Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 03-11-2004, 10:34 AM
ccm ccm is offline
ccm is on a distinguished road
Home Built Tubing Bender
Has anyone found and good plans on the web anywhere for something along these lines ?
I've got most of the hardware to build a ram style machine with two guide rollers on either side of a ram arm with a die on it.
I've got the steel stock, and hydraulic pump but need a cylinder and gang valve to construct one myself.
If no plans that anyone knows of ...... then can someone suggest some online links to some surplus hydraulics equipment ?
thanks all,
art
Old 03-11-2004, 02:22 PM
Bloy2004's Avatar
Fumbling Machinist
Bloy2004 is on a distinguished road
try this site:
http://www.surpluscenter.com/hydraul...name=hydraulic
Old 03-11-2004, 03:46 PM
Gold Member
Ken_Shea is on a distinguished road
CCM,
Here is a link that may offer some ideas, no plans but lots of pictures and some advice.
Ken
http://www.blindchickenracing.com/to...bingbender.htm
Old 03-11-2004, 04:59 PM
High Seas's Avatar
Gold Member
High Seas is on a distinguished road
ccm -
if those bits (cylinder and gang valve) run you more than 70 bucks you can get a charlie-chan (chinese built - no offense intended!) thru Homier. Saw the whole set up today at the truck sale - looks usefull and had several sets of formers too - but for pipe bending. It was a 12 ton ram.
Jim
Experience is the BEST Teacher. Is that why it usually arrives in a shower of sparks, flash of light, loud bang, a cloud of smoke, AND -- a BILL to pay? You usually get it -- just after you need it.
Old 04-02-2004, 12:13 AM
vladdy's Avatar
vladdy is on a distinguished road
depends on what you want to bend, pipe [thick wall] can be done on almost any type of bender..but tubing [thin wall, needs a 'mandrel' or similar style of bender, I've used a HOSSFELD, worked pretty good, a muffler shop style of machine 'squashes' the pipe down a bit at the bend points.. small stuff can be bent with an electrician style foot bender [one size, one die..]
enjoy..
Old 05-27-2004, 11:22 PM
tpworks's Avatar
tpworks is on a distinguished road
Harbor Freight $89.00 pipe or tubung bender, Bends 6 different diameter pipes from 1/2" to 2". Bending bars can be adjusted to distances of 8-1/2", 11-1/4", 12", 16-3/4", 19-1/2" and 22-1/4". 2" diameter 12 ton jack. Jack capacities: 13-1/4" minimum; 22-3/4" maximum; 9-1/2" stroke. Precision cast dies.
http://www.harborfreight.com/cpi/cta...emnumber=32888
Tom
...He who makes no mistakes makes nothing! ...
Tom
Old 05-28-2004, 12:17 AM
Sanghera1 is on a distinguished road
Try Princess Auto, they should have some stuff there.
Old 05-28-2004, 05:36 PM
mysterious's Avatar
mysterious is on a distinguished road
The HF bender is good for heavy "pipe", but for actual tube it will kink the heck out of it. You will have to buy a "tube" bender for tube, or if you make your own at the very least buy some tube dies, which are pretty pricey themselves.
Old 10-11-2004, 07:26 PM
Tazzer is on a distinguished road
try minichopperplans dot com as they have two sets of plans that you can buy for twenty bucks they will bend .5" to 1.5" tubing. The only tricky thing is the die which can be machined easily.
I am currently making one out of scrap metal and so far has only cost me $10 for a 4 ton jack.
Give me a e-mail if you have any other questions about the plans.
Old 10-12-2004, 10:21 PM
mikewood is on a distinguished road
The HF bender is a rigid conduit/schedule 40 pipe bender. It is very accurate for rigid electrical conduit. It is slightly less accurate for schedule 40 aluminum. It is worthless for thin walled tubing. There are shoe-type benders that will work with standard electrical tubing, which is a great resource. There is also a hand held "pipe hickey" which pros use to bend rigid electrical conduit, but it takes a while to learn to master it.
  #11   Ban this user!
Old 10-13-2004, 12:52 AM
rc-cellar is on a distinguished road
http://198.247.193.8/wwwroot/greenlee/bending.pdf
Here's what most all electricians use to bend conduit over 1" dia. There are some hydraulic ones like you describe further down. You'll need a different shoe for every pipe diameter. If it's wrong, the pipe will kink or flatten out.
If it ain't broke... fix it 'til it is.
  #12   Ban this user!
Old 10-16-2004, 07:26 PM
Senna's Avatar
Senna is on a distinguished road
Home built tubing bender...
How about making a roller bender??? I remembered a long while back Mother Earth News had one in their mag... I found it in the archives...
http://www.motherearthnews.com/arc/1857/
The size can be modified for the particular need...
Hope this helps...
Steve
Crooked River Ranch, OR
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
Home built CNC mill #2 jimglass General Metal Working Machines 1 04-03-2008 05:29 PM
Home built barfeeder Fudd General Metal Working Machines 2 01-28-2008 09:50 AM
Another home built router :) steveald DIY-CNC Router Table Machines 69 03-19-2005 01:22 PM
Home Built Router/Drag Diamond Engraver DaSigntist DIY-CNC Router Table Machines 49 01-24-2005 02:02 AM
4-5 axis control recomendations for home built horizontal machine Kmed General CNC (Mill and Lathe) Control Software (NC) 3 01-17-2005 05:04 PM
