Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 02-23-2007, 04:27 PM
morribi is on a distinguished road
Tube Bending Machine Capable of 2"x4" Rectangular Tubing
I am wanting to design a tube bender capable of bending 2"X4" rectangular tubing.Do anyone knows how to calculate how much force that would be required to bend tubing this size?I was thinking maybe building a cnc mandrel tube bender using a 40 hp electric motor.Input would be greatly appreciated.
Old 06-06-2007, 11:18 AM
mikek10 is on a distinguished road
Material and wall? Easy way or hard way? Bend radius?
Old 06-06-2007, 11:30 AM
Hey Mikek10
Mikek10,
Thank you for responding. The material is 2"X4" mild steel and the minimum wall thickness is .25". I will be bending the easy way and the bend radius will be 10 inches up to 13 inches.
Old 06-07-2007, 03:27 AM
The figures I am getting are:
Bend Force = 0.8 Newton Metres
Pressure Die Force = 285.7 Nm
Mandrel Force = 114.3 Nm
Clamp Force = 114.3 Nm
Wiper Die Force 85.7 Nm
I would work on a safety factor of at least 3, probably more on the bend force which looks surprisingly low to be honest
Old 08-22-2007, 06:49 AM
I must have been having an off day when I worked out the figures above - did them in mm rather than inches!
Real figures are:
Bend Force = 9365 Newton Metres
Pressure Die Force = 184335 Nm
Mandrel Force = 36867 Nm
Clamp Force = 36867 Nm
Wiper Die Force 55301 Nm
Old 10-26-2007, 09:45 AM
fjcruiser is on a distinguished road
Mike,
What equations are you using for those calculations? I am interested in being able to calculate various round tubing (steel) sizes and wall thicknesses. Any help would be greatly appreciated!
brodybaker@gmail.com
Old 10-26-2007, 10:47 AM
I work for a company that manufactures tube bending machines.
We have written a program to do these calculations for inhouse use and for doing xyz>ybc conversion etc. Though we have sold copies on occasion
Old 11-01-2007, 12:38 AM
racesol is on a distinguished road
You can't apply force with the wiper die. The mandrel force = clamp force doesn't make any sense either.
Old 11-01-2007, 08:40 AM
Its the force against the wiper
mandrel force always equals clamp force
Old 06-27-2010, 11:47 AM
LRuley is on a distinguished road
I'm not able to help you with machine design but our company currently has machinery and tooling capable of bending this to an 11" clr or 13" clr if you are interested in purchasing the parts rather than building the machine. Thanks.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 01:15 AM
BattleAxe "aka" Ball and Chain "aka" the wife. ZipSnipe CNCzone Club House 48 05-18-2008 10:53 AM
Questions on building small (18" x 24" x 3") machine bikedude880 DIY-CNC Router Table Machines 4 07-31-2006 10:04 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 10:09 AM
Add "View New Posts" to "Main Menu" Mr.Chips Forum Questions or Problems 4 04-21-2004 11:54 PM
