Results 1 to 8 of 8
Thread: Bending
    Jan 2004
    Ann Arbor, MI
    Bending
    I was wondering if there is a machieni can build or somehow bend aluminum in liek 90 degree and 45 degree angles......
    Basically i am looking to create a bender.
    Thanks guy,
    Wakeboard
    Moderator HuFlungDung's Avatar
    Mar 2003
    Hi Wakeboard,
    Yes there are machines available. If you want to bend sheet metal, the machine is called a brake.
    For heavier sections, a hydraulic press would commonly be used. This requires a male/female die combination to create an accurate shape. Lots of guys build their own hydraulic press frames, using an inexpensive hydraulic jack to create the needed force.
    Oct 2003
    Palmer,Alaska
    Take a look in the ENCO 2004 Master catalog page 487. If that doesn't inspire the DIY in you, nothing will. Gee I think I just found another winter project ( Ya think it can be NC'ed ?).
    Jan 2004
    Ann Arbor, MI
    Ok I am gonna be building a hydraulic press then.....are there any good sites or places you can direct me to?
    What is this ENCO? Anyone have a link?
    Thanks,
    wakeboard
    Jan 2004
    WWW.use-enco.com. They have all sorts of great stuff. Really all you need to do to build a press, is build a rectangle out of extremely stout metal. I-beam would be the most substantial and stout. Build a bracket that sandwiches one side of the ibeam. Sorry, build two of these. a pieace of I-beam goes in between them, and...oh hell, let me draw it up. I'll be back.
    Stop talking about it and do it already!!!!!
    Jan 2004
    Damn! Still can't seem to get a file that is less that 700000 bytes. Anybody got any tips? Well...send me your email address, and I'll email you the drawing.
    Jan 2004
    Ann Arbor, MI
    oh sweet hobbiest thanks!
    dassanis@yahoo.com
    Gold Member Mr.Chips's Avatar
    Sep 2003
    USA Tucson AZ
    Hobbiest,
    Someone in CNCZone gave me this software tip. Use http://www.irfanview.com/ to change file size and other things, it's a free download.
    Hager
    1. bending cast iron
      By Goofour in forum Bending, Forging,Extrusion...
      Last Post: 10-21-2006, 01:38 PM
    2. mandrel bending
      By MBG in forum Bending, Forging,Extrusion...
      Last Post: 03-22-2005, 02:29 PM
    3. Bending small aluminum rod
      By Twmaster in forum Bending, Forging,Extrusion...
      Last Post: 08-06-2004, 08:50 PM
    4. Tube and profile bending
      By motordude in forum Bending, Forging,Extrusion...
      Last Post: 03-12-2004, 11:01 AM
    5. Bending info
      By Klox in forum Bending, Forging,Extrusion...
      Last Post: 05-13-2003, 11:00 AM
