Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 09-20-2006, 06:40 AM
mickmf is on a distinguished road
brake press basic operation/tutorials
hello all its a few years since i last operated a brake press , i am trying to find a tutorial online that gives me the basics.
main confusion is if i want to form a series of bends in sheet metal is how i work out the folding sequence and relevent bend allowences and backstop positions.
i cannot find any demo software for download to assist in this area , vidios etc are very expensive, here in the uk books on this subject do not seem to exist, have contacted brake press manufactures in the uk but still cannot get much info unless i actualy purchased a brake press.
i am a sheet metal worker but unemployed at the moment most firms want people that can operate a brake press but are not willing to provide any modest instruction in there usage.
thank you
Old 09-20-2006, 06:53 AM
Gold Member
InspirationTool is on a distinguished road
There's a guy on ebay who sells a press brake instructional book. I remember it was fairly cheap and looked pretty good.
-Jeff
Old 09-20-2006, 02:43 PM
schiada96 is on a distinguished road
Talking
press brake not brake press
Old 09-20-2006, 04:07 PM
One of Many is on a distinguished road
Have you looked into any local trade school courses offered on this subject. They may have books for those courses.
I have seen this book available through Amazon.com. Price is a bit steep, but rare industrial text type of books do not sell by the millions.
Press Brake Technology
I figured I would add this in here too. I worked with the Author of this book and had a couple training classes he taught a few years back. Ben is retired now and it does not suprise me he has put at least a portion of his vast tooling knowledge and experience in print. Ben was one of the premier press brake tooling engineers in the industry for some 40years. Many of the bend tonnage charts you see probaby have Ben's bend data adopted throughout the years.
Press brake tooling fundamentals
There is a wide array of knowledge required to first of all stay safe on these machines and secondarily skilled enough to make accurate parts with little to no scrap materials for trial runs .
Bend allowances are available on charts for rough starting figures to calculate blank sizes. Some guys will use material thickness and/or lower V-die widths to come up with material consumption figures. There are different types of bending procedures(air bending, bottoming and coining) that can alter these estimates, so it becomes experience that will be applied in each condition as required. Variances in upper die nose radius and material spring back also play a role. I sincerely think you need to work with the die combinations on hand to know what to expect first hit, then judge accordingly.
Bending tonnages are based on a combination of the lower V-die width in relation to material thickness. This is also available on charts. With the advances in hydraulic CNC press brakes, the settings can be controlled so that the maximum tonnage for the dies is not exceeded before a position reversal is reached. Not so with the old mechanical eccentric conrod machines that would attempt to move regardless of impending disaster.
The key here is knowing the material and its bend factor and/or if it is bendable at all without fracture or worse. Then selecting the proper dies and tonnage required to fit the machine and die set safely.
Much of this will be machine dependant as to what skills are needed BEFORE you pull the trigger. The methods and tricks of the trade will come as you gain some first hand experience at setting up for the next challenging part. That includes knowing where to start to make consistent parts and what bend(s) can be used off the back gage to maintain tolerances.
Just don't volunteer to chip form 3 tons of 4" plate steel.
DC
Learn cause and effect through experience. Mastering those relationships is the "Common Sense" ability within the art of any trade.
Old 09-20-2006, 05:24 PM
la_coterie is on a distinguished road
I was also a SMW ended up as Workshop manager then jacked it all in to live in France
You say you're a SMW so you will know how to work out the order to fold things. Its over 10 ten years since I used a press brake in anger, well at all actually but experience tells you how to fold it. Its only the sh*tty shape that need a bit of thinking and they don't occur every day.
Now the control - that's a different story. I was instrumental in purchasing a couple of Trumpf press brakes, but b*ggered if I knew how to work them!
If I was still WS manager looking for somebody to hire I'd be looking for somebody who could read a vernier, as you say do bend calcs, and have a fair idea of the order to bend things. Not really bothered about the control cos you'd be lucky to find somebody who's used your type of control before.
If as you say you're a SMW I'm puzzled that you don't have much of a clue on bend calcs and the order of folding?
Anyway as you probably know it's all ball park stuff and if it's that critical you have to use the tried and tested suck it and see method - it all depends on the material, vee size, vee rad, grain and which way the wind is blowing.
In the CNC world most things are either pre punched or lasered so somebody? (hopefully) has done the bend calcs right
Anyway, most shapes that I came across could just be bent from the outside in. Those requiring starting in the middle count as sh*tty shapes and you usually end up punting 0.2mm around the sheet to get it in tolerance.
enjoy - it kills your feet. (think flamingo)
Old 09-21-2006, 07:03 AM
thanks all i can use a vernier and work out bend allowences etc, what i cannot exactly recall is how one sets up the backstop in relation to fold lines on part to be formed.
seem to recal would measure from center of bottom vee to the back of bottom tool say 50mm,
if i was using material 3mm thick which for example bend allowence /deduction was 4mm wanted first fold 40mm in from stock at 90degrees backstop would be set at 50mm +40mm - 2mm =88mm backstop setting to fold material,
if my next fold was 80mm in from the first fold and reverse direction how i calculate correct back stop distance in relation to the second fold ,not sure if its thickness of material or half bend deduction???
and consequent folds
thank you
Old 09-21-2006, 09:12 AM
backstop = inside leg measurement to foldline nothing more complicated.
centre of vee to backstop = inside leg measurement.
above gives reasonable results using vee 8x(ish) thickness
Depends on how accurate you want it. If it was a spotty b*llocks job we'd use a bit of scrap to test fold using as above then adjust as needed.
Cut piece 100mm wide measure - fold 90 deg BS=50 measure o/a dims - add up - take of 2x thickness difference between start flat sheet and your number now is bend allowance - sod all those silly calcs ;-)
Second fold pretend the first ain't there same rules as at top above - don't forget retract and delay if stop gonna move in... that can make a mess..
Old 09-21-2006, 04:11 PM
Al_The_Man's Avatar
Actually I think it is always misspelled, shouldn't it be BREAK?
Old 09-22-2006, 06:36 AM
thanks all not sure what inside leg measurement refers too ???
if i wanted fold to be 40 mm in from edge of stock ,and finished flange height 20mm (outside dimention) set backstop 60mm -2 thicknesses say stock 2 mm backstop setting from middle of vee 58mm which would be center of fold.??
thank you
Old 09-22-2006, 07:58 AM
1/3ir + mt x 1.295 is the bend deduction formula for a 90 degree bend.
  #11   Ban this user!
Old 09-22-2006, 10:46 AM
hi Schiada96
Depends what material and what size Vee and what shape punch and what way the wind blows.
What I'm basically saying is that you can get a rough size from calcs which are normally good enough. but if you want it spot on test with a piece of the sheet you're goning to use
Our favourite for sheet - i.e, 3mm & less inside dims added up - works for us on mild steel in 8x mt Vee
  #12   Ban this user!
Old 09-22-2006, 11:17 AM
Ok so you're not a SMW but you want to be,
I don't know anybody thast calls the sheet "stock" you must be a machinist
OK post #6
centre of vee to back of vee you say hypothetically 50mm just think about it draw it out. You want a 40mm fold, you say 40mm in from stock? I presume you mean 40mm in from edge so thats 40mm inside? assuming the vee is less than 80mm you can fold it (normal around 25mm) Think where does the punch fall? (top tool) in the centre of the vee. So logically the backstop will be set 40mm back
In reality backstops are tuned to give inside leg dims which words fairly well on the thinner stuff as I said if in doubt use a bit of scrap to test
So you're descibing a Zed section, first fold 40mm inside (43mm overall). Height of Zed 86mm overall
Fold 1 BS = 40mm
Fold 2 BS = 83mm retract + pause before return to 40mm
It don't matter which way the fold goes for bend calcs
we are of course talking CNC stuff here.
Maybe they call sheet stock in your neck of the woods, then keep on calling it that, but then you'd be a stock metal worker
Simply, backstop zero = centre of vee
