Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
  #13   Ban this user!
Old 09-26-2006, 06:51 PM
schiada96 is on a distinguished road
Originally Posted by la_coterie View Post
hi Schiada96
Depends what material and what size Vee and what shape punch and what way the wind blows.
What I'm basically saying is that you can get a rough size from calcs which are normally good enough. but if you want it spot on test with a piece of the sheet you're goning to use
Our favourite for sheet - i.e, 3mm & less inside dims added up - works for us on mild steel in 8x mt Vee
The formula is north american avations. You make the material form to the inside radius you want not what it wants. I have found this formula to be best and consistent to within .002.
Jeff
  #14   Ban this user!
Old 09-27-2006, 02:27 AM
la_coterie is on a distinguished road
Aircraft sheet metal now that's further up the food chain and your material is better quality
  #15   Ban this user!
Old 12-04-2007, 01:25 PM
bob mascaro is on a distinguished road
Red face bend deduction
i agree .. i get so tired of aaarguing with people over microns ..lol .In sheetmetal the thickness varis more than bend allowances not to mention coinage are concerned .
Its bend dedution and twice the metal thickness is the answer. Bob ie the solidworks guy with 20+ yrs fab exp.
  #16   Ban this user!
Old 12-04-2007, 01:58 PM
Cor more than year since this was last aired!
Strange that the originator of the question hasn't posted any more, maybe he was a troll. Not the most obvious thing to start an agrument on though.
Yeah Bob, I agree. how big is a micron anyway
If you need it that acurate the design must be crap, or go and machine it out of a lump of solid!
I dunno what your sheet tolerances are across the pond, I guess the same as UK +/- 10%
You know sheetmetalworkers are miracle workers really
www.la-coterie.com for holidays in France
  #17   Ban this user!
Old 12-06-2007, 08:30 AM
Beg to differ but your formula will be wrong with a insde radius of .03 by about 1/16 on .125 thick material. Tell me what solidworks comes up with for .125 thick material on with a inside radius of .75.
And if your material thickness is varies that much please find a new suppiler. You are talking about thickness variences of .100?
  #18   Ban this user!
Old 12-06-2007, 12:11 PM
Thumbs up huge radius
see thats what im talking about lol. and by the way what kind of repeatability do u expec to get with a 3/4'' radi on 11 guage ,surley u dont expect to hold that flange length anywhere near std. tolerances unless its only a few feet long? try stamping or coining maybe.
  #19   Ban this user!
Old 12-06-2007, 01:22 PM
not true at all
the formula is for right angle 90 degree bends u have to go into bend allowances for more acute or obtuse bends
  #20   Ban this user!
Old 12-06-2007, 01:31 PM
brake
actually its called a brake because it has a brake just like a car or at least the old ones did (conventional) . there was a fly wheel that actuated the ram
some peeps called it a clutch so we could also call it a clutch press if we wanted to . Even the hydraulic press have whats called a brake valve
  #21   Ban this user!
Old 02-25-2008, 05:56 PM
3d Laser is on a distinguished road
Post LVD MNC 800 control
Hi Guys, this is our first time to writing here.We bought LVD Brake press with MNC 800 controller. We found three big cards not working, please if anyone can help us to find those card that would be great help.
  #22   Ban this user!
Old 02-26-2008, 07:33 AM
true
yes thats correct but u can also use k-factor or bend deductions and allowance . but the point is that unless your bending plate or building space ships comprised of titanium lol its a waste of time,but now if your useing a
3d programs like SolidWorks i go ahead and use allowance
  #23   Ban this user!
Old 06-17-2008, 05:36 PM
PhoenixMetal is on a distinguished road
Press brake backgauge controls are notoriously unreliable (at least the old ones are). There are many companies that will repair the boards for you, typically at a cost of $1,000 to $1,300 each, but the sad fact is that within a short period of time, those same cards (or other ones in the same system) will fail again.
My solution has been to replace the electronics with my own and I write a program on the computer to control them. I used a controller from Galil on one system, and a controller from Anaheim Automation on another. If you know how to do this (or can figure it out), you can replace the controls with your own for around $1,200, and will be much happier for it.
The PC controlled solution is also superior in many ways - for example, its much better in my opinion to be saving the part files on your computer than it is to save it on a proprietary control mounted on the machine.
This solution can also be much more intuitive for the machine operators. For example, I have my systems output to the monitor "Bend 1, Burr up" "Turn part 90 degrees" etc, and have also translated the instructions into Spanish when needed.
So in my opinion, when your press brake backgauge controls break, don't fix them. Replace them.
  #24   Ban this user!
Old 07-19-2011, 11:57 PM
jmkelkar is on a distinguished road
Hello, I have a bit of a basic question. I have seen that when we bend a long sheet about 4 mm thick at right angles for a small length sheet length 3 metrs and fold length 55 mm., we need a huge manpower ( about 12 persons) t0 Throw up the 3 meter lenth of the sheet up in the air to facilitate the bend as the ram bends.
Is this the correct method? Is there any mechanical arrangement to lift the sheet as bending happens? I am curious to know this.
