Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 01-13-2012, 06:39 PM
jeffrey001 is on a distinguished road
DIY hydraulic cylinder
Hi, I need to made custom hudraulic cylinders and would like to know if anybody have plan to do it or could give information.
Need to be around 4 to 5 inches bore and 5 inches stroke.
Rod need to be around 1.5in.
I don't know how to make this and what seals I need and tolerances for the bore.
Something like that:
Old 01-13-2012, 07:35 PM
rockcliff's Avatar
rockcliff is on a distinguished road
DIY Hydraulics is probably not the best idea, but if you absolutely positively must make cyl's yourself
I have often used the literature at Parker for quite a few things I have designed for Hydraulic seal components, they have a good engineering library.
Parker - Engineering Your Success
Rockcliff Machine Inc.
www.rockcliffcnc.com
hydraulic cylinder positioning atvracer General Metalwork Discussion 0 06-30-2011 10:35 PM
5x6 bandsaw hydraulic feed cylinder jakemestre Benchtop Machines 4 06-18-2011 09:56 AM
Need Foot Control Valve For Hydraulic Cylinder mschjone Hydraulic Equipment 0 02-24-2011 10:38 AM
CAN MACH CONTROL HYDRAULIC CYLINDER? beezerlm Mach Software (ArtSoft software) 29 12-09-2010 08:25 AM
Hydraulic Cylinder Casing Turning? Moparmatty General Metalwork Discussion 9 10-06-2008 05:53 AM
