Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 10-04-2011, 07:43 AM
arnoldino is on a distinguished road
Delem DA58 control signal
hello,
we have a press brake with DA58 control system, and the press brake is defected.
when I want to make the reference stroke for the Y axis, one side is falling down and the machine stops in emergency stop, because it is inclined.
I found that the error occurs with one of the magnets on the main hydraulic block.
I checked the cables from the DA58 to the magnet, and it is OK. so it looks that we have controlling error.
can somebody advice me something? at least some electric plan for the DA58, to be able to check the electrical components?
thank in advance.
regards,
arnold
Need Help!- Delem DZ-65 on a FASTI 215 40/4 meshteru Bending, Forging,Extrusion... 1 10-17-2010 12:26 PM
Newbie- 1.6V-3.0V random signal voltage parallel signal from output – Any advice? cjchands Mach Software (ArtSoft software) 0 11-12-2009 04:36 AM
Delem DA65 cncdiag Bending, Forging,Extrusion... 3 06-16-2009 11:35 AM
Z axis signal to control power supply oneeye General Electronics Discussion 2 02-13-2009 08:14 AM
Delem DAC 350 cnc controler.. hotponyshoes General Electronics Discussion 0 04-17-2007 02:33 AM
