| Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here. |
| I just googled these. Wood's metal - Wikipedia, the free encyclopedia How to bend tubes Do good research on prices for the stuff. $16/lb looks OK. Beware of high prices. You may find better. You will still need to form over a mandrel, but at least the walls won't crush.
__________________ Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way. |
| Review tolerances with the customer. Is the 4-place decimal a result of a default CAD setting or is it really necessary and what does it mean, if it's +-.001 you're setting yourself up for headaches & failure because that's unattainable with the tubing called out. The tolerance needs to reflect the standard tubing tolerance PLUS reasonable processing tolerance. |
| No,the tolerances don't need to be that tight. Just did a rough drawing. The updated specs are below. I looked for a supplier online, but I didn't have any luck. I can change the size if there is a supplier that has something close. Thanks for the help |
| While this isn't the radius you need, they may be able to help you out; 1.63" Mild Steel, 2.50" Radius, 11 Gauge, 180 Degree Mandrel Bend Columbia River Mandrel Bending |
| Newbie- tube endforming equipment for telescoping tube | DanP | Want To Buy...Need help! | 2 | 01-23-2012 04:32 AM |
| Newbie- Tube cutting; tin slots and tube ends | marineboy | CNC Plasma and Waterjet Machines | 0 | 10-13-2009 04:03 PM |
| Best Way to Bend Aluminum Tube ??? | twocik | General Metal Working Machines | 18 | 07-22-2009 01:39 PM |
| Looking for someone to bend parts! | CoolhandLuke | Bending, Forging,Extrusion... | 4 | 02-20-2007 09:03 PM |
| Bend-Tech-ez | diarmaid | Mechanical Calculations/Engineering Design | 5 | 09-23-2006 11:19 AM |
