Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Bending, Forging,Extrusion...
Bending, Forging,Extrusion... Discuss Bending, Forging, Extrusion technique's here.
Old 06-13-2011, 02:29 PM
twocik is on a distinguished road
Shop press, Break or ???
Wanting to bend mostly 1/8", 3/16" and 1/4" aluminum 6061-T6 plate. The parts are pretty small (3" W x 11" L) and only need 45° - 65° bends. What piece of equipment would you recommend under $600 ?
I was thinking a 12 ton shop press with a few custom welded tips and fixtures. I was going to have welder weld me a round bar fitting to the hydraulic cylinder shaft, then press into two round bars separated at the correct distance as my die. What do you think ?
Old 06-13-2011, 02:57 PM
keebler303 is on a distinguished road
get a cheap press like this: 20 Ton Shop Press. You can get a 20% off coupon from almost any magazine these days. Then you can use angle iron, structural steel shapes, etc. welded together to make your dies. It won't be perfect but you can do a decent job if you make yourself some decent tooling. There are some manufacturing type companies that have chunks of broken press brake tooling you might be able to get for next to nothing. My neighbor stocked up on some nice tooling from a company who makes elevators.
Matt
Old 07-05-2011, 11:59 PM
After 5 weeks Harbor Freight finally got one in stock. I'm looking at the Swag 20 ton press brake kit and seems to be within range. Not sure how big of a deal the leafs to each side of the top cylinder where the hydraulic shaft fits into are (doesn't have them), but seems to be a pretty good working device.. . Any thoughts ?
20 TON Press Brake DIY Builder Kit
Need Help!- amada break press mike 82 General Metal Working Machines 4 06-09-2011 08:26 AM
Problem- amada break press mike 82 Bending, Forging,Extrusion... 0 06-02-2011 05:45 AM
Need Help!- Selecting Press for home shop press brake tikka308 Bending, Forging,Extrusion... 0 12-28-2009 10:51 PM
MasterCam for a CNC Press Break & Shear? Miguel Gonzalez Mastercam 4 05-23-2007 12:26 PM
CNC Press Break & Shear Miguel Gonzalez Bending, Forging,Extrusion... 0 05-14-2007 02:16 PM
