Results 1 to 5 of 5
Thread: Anyone know how the barb of a fish hook is made?
    Jan 2011
    I am developing a tool that needs some high strength steel wire to be formed with something that would resemble a fish hook barb except that it would have two barbs opposite each other. The wire is about the same size as a small fish hook and the barbs would actually need to extend a bit further than most hooks do. It also doesn't need to have a U bend like a fish hook.
    I imagine the tool might be a small press or forge but the parts are very small compared to what I am used to.
    Thanks for any input.
    Rick
    Registered bobsch's Avatar
    Oct 2008
    I think the barb is stamped. Here's an article that might help: http://www.howtofishguide.com/tackle...-fishing-hooks
    Bob
    "Bad decisions make good stories."
    Jan 2011
    Thanks Bob,
    That's about as much as I could find too. I think the machines they use now may be closely guarded secrets because there doesn't seem to be any patents for them.
    The steel they use (and I want to use) is pretty high strength stuff and would be tough to form, so I suspect they must use carbide punches or dies. I can machine some O-1 dies but I'm not sure if they would hold up. I could also make a copper plug for a sink EDM and get them made out of some carbide inserts.
    Anyone have any suggestions or recommendations?
    Thanks again,
    Rick
    Oct 2008
    Going from memory here, but I think they form the hooks and barbs then heat treat them.
    Bob
    Jan 2011
    I'm pretty sure you're right. They would want to work with annealed or at least normalized material first, then heat treat to harden.
    Depending on the material I use and whether I hot or cold forge, it may work harden enough to be able to skip the heat treat process. However, I'm sure I would need to use carbide dies then.
    Rick
    1. Fish cut in a quarter.
      By EDM_Fixer in forum Machine Created Art
      Last Post: 11-05-2010, 09:36 PM
    2. Software for fish tank cabinets.
      By woodmaster in forum General CAD Discussion
      Last Post: 10-10-2010, 05:00 PM
    3. fish plate
      By woodman08 in forum Gorilla CNC Machines
      Last Post: 08-22-2009, 01:38 PM
    4. low heat solder paste on a fish hook
      By skipperspride in forum Welding, Brazing, Soldering, Sealing
      Last Post: 04-20-2008, 07:18 PM
    5. Need help with Brazing brone fish hooks
      Last Post: 01-28-2008, 01:22 PM
